It sounds like you might be dealing with a defrost drain issue or a problem with the freezer's door seal. Try defrosting the freezer and clearing any ice buildup, then check the door seal for any gaps or damage. If the problem persists, you may need to consult the user manual or contact a professional appliance repair service for assistance.
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
The defrost element has failed, ice buildup will be noted at the inside rear of unit lower. Replace defrost element (service tech required). fixed and many years trouble free, very common.
The drain pipe is most likely blocked. It is a plastic tube about 10mm diameter, as you've probably noticed. Try reaming it out gently with a wire hanger.
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around.
A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Things to look for and fix yourself woulf be to clean the coils on the bottom and check the fan motor on bottom, make sure it is ok, Look on back of the freezer walls for frost buildup, a sign the defrost heater is dead.
There is normally a small filiament of metal which is attached to the defrost element and conducts heat down the drainpipe preventing ice build up. You can pour some boiling water onto this area and even wriggle a piece of plastic tubing down the drain pipe to dislodge any blockage. For future prevention, you can attach a piece of copper wire around the defrost element (in the absence of the original filiament) and extend it down the drainpiple
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close thedoor to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
