Sansui RZ 8300 AV Receiver will not turn on flicker on and off. Power turns on but when the standby button pushes in it just flickers on and off.
  • 1,512 Answers
Hi curtmalm
First, do a rest on the unit by disconnecting from the wall overnight. Then fire it up again to see if it recovers. Let me know here how you go.
regards
Graeme
Posted on Apr 14, 2008
Television is on standby-red light is flickering but the set will not turn on
The power supply needs to be repaired or replace the Module.
Nov 01, 2012 | Televison & Video
SANSUI STEREO AV RECEIVER RZ -2605AV NO SOUND
Sansui RZ-2605 A/V Receiver no sound
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 07, 2012 | RCA Audio Players & Recorders
How do I connect Subwoofer in sansui rz 5200 av model receiver?
You could refer to the instructions presumably available for the unnamed sub. THAT would determine the methods it can use.
Aug 17, 2011 | Sansui RZ-5200AV Receiver
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
I have a sansui stereo av receiver rz 7000 from 1990 which works on 110 220 230 volts and the receiver has a voltage selector on the back - I need to understand how to move the selector from 220 to 110...
Remove the fuse cover with a flat screwdriver, then pull the surrounding circular black plastic piec straight out and reorient it to show the desired voltage, then plug it in, insert the fuse and cap.
Nov 24, 2010 | Sansui RZ-8150AV Receiver
Receiver display started scrolling fast through set-up options on it's own and then stopped scrolling with "V1 PLX Movie" in the display and none of the front panel buttons including the power switch have...
Try this, but you'll lose any presets and setups.
it on and, while holding down the [VIDEO 1] button,
press the [STANDBY/ON] button. “Clear” will
Standby mode.
Jun 09, 2010 | Onkyo HT-S790 Home Theater System System
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Sansui
I need a card with SMD ICs located on the circuit board of my sansui RZ6800 AV Reciever.(its a digital card with function IC and many more SMD components)
Sep 01, 2007 | Audio Players & Recorders
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Feb 01, 2007 | Sansui RZ-5300AV Receiver
309 people viewed this question
 Grubhead
Grubhead
