Try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
