Question about Acer Aspire 5630 Notebook
BIOS Date and time not advancing
Hi. I have an Acer Aspire 5630 laptop that keeps losing time. When the BIOS screen is selected (F2 at boot) I have noticed that the System date and time stays static and despite upgrading the BIOS to 3.23, it still fails to change. I am able to overtype and update it but clearly there is something else wrong. My guess was that the CMOS battery had died but looking at forums, it would seem that other bad stuff would happen if that were the case. Does anybody have experience of this please? Thank you for any help and advice. Steve
  • Anonymous May 07, 2008
    I have the same trouble with a Acer Aspire 5635WLMi, BIOS updated to 3.5 from Acer-Europe FTP.
    Genius:
  • 1,226 Answers
I experience that already, system date /time is loosing, You need to replace the cmos battery and set the time in the bios setup.
I guess there no other fault except the cmos battery busted.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Apr 14, 2008
Hi, I have an acer aspire notebook thats 10.1 led screen. Whenever I try to turn the wireless capibility on, it always shows a red "X" on the thing that pops up, any help would be great. thank...
It may happen if the BIOS setting are corrupted, please load the BIOS deafults, to do so
1. Shutdown the computer.
2. As soon as you hit the power button to turn it ON, keep on tapping the F2 key, it will go to BIOS screen
3. Press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are prompted), it will restart the computer.
4. Now, keep on tapping F8 key, now select "Safemode with Networking" from the Advance boot menu. Try to connect to internet. If you are able to connect to Internet then the issue is with the firewall on you computer, contact the firewall manufacture or settings. If you are still unable to connect to Internet, then the internet setting are not correct, you may need to contact the ISP.
Thanks and regards,
Jitha
Nov 24, 2010 | Acer Aspire One Netbook 8.9" Notebook
On startup of my acer aspire 5315 laptop i get the message " no bootable device insert boot disk and press any key"and nothing i have tried can get me past this screen.I can't even get get into...
Hi Charles, I apologize for the inconvenience. In this case what you could try is to get into the BIOS screen for the laptop by pressing the F2 key as soon as you turn on the laptop.Once you are in the BIOS screen please use the right arrow key to select the tab "Boot" below boot make sure that the hard drive is the 1st boot device(you can change the order by using the F5 and F6 keys) and then load the default settings in BIOS using the F10 key and select "YES" and the computer would restart once.In case after performing the above steps the issue still persists then the issue is with the hard drive on the laptop not being detected and if the computer is still covered by warranty please contact Acer and do get the laptop repaired or else you could have a local technician replace the hard drive for you.
Best wishes for your effort.Thank you for your time and patience.
Nov 12, 2010 | Acer Aspire 5315 Notebook
Bios password
to get rid of passwords in bios, removing the small computer battery that keeps the time on your computer will work. only sometimes though
Apr 30, 2010 | Acer Aspire One PC Notebook
Hi. The clock on my Acer will not keep the correct time any more and it doesnt change dates on the calendar either. Do I need to change a battery in my motherboard?
If you change the BIOS date and time and when you boot up next time and the date and time has changed back or is incorrect, then the most likely fault is a flat BIOS battery. Replace the BIOS battery, it maybe a coin type lithium 3volt battery. this is the most common type used in motherboards is a CR2030 lithium battery.
Nov 03, 2009 | Acer Aspire 5630 Notebook
Blank screen problem
hi,
1.Please keep pressing and releasing F8 key when ACER logo is coming.
2.start the computer in safe mode by selecting it in advanced OS choice menu.
3.If started in safe mode go to programs>accessories>system tools>system restore and restore the system to a back date by selecting a bold previous date in calender.
Idf not booting in safe mode also you may need to reinstall the OS again.
Jul 06, 2009 | Acer Aspire One PC Notebook
How can I password-protect all files on my laptop?
Hi there.
You can set a bios and hard drive password either by using Acer Empowering Technology application or entering the bios itself by restarting the computer and hit F2 while its just starting up, make sure you keep your password safe because if you forget the the passwords you may find yourself locked out of your own computer and bios passwords are very hard to crack.
Good luck and thanks for using FixYa!!
May 13, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My acer laptop won't boot pass the acer logo sign.
Try this - go to BIOS (while you see ACER logo press F2 (or other key, it should be shown below the logo)) and select setting called something like "Restore Defaults" or "Load System Defaults" or "Optimal Settings". When it asks "Are you sure", pres Y then Enter. Tell me what happens.
Mar 15, 2009 | Acer Aspire One PC Notebook
Format pc laptop
if you wish to do a full system factory recovery, on boot up press Alt & F10, or press F2 or Del on boot up, select the cdrom as first boot device and insert windows cd, save settings and exit for a reboot.
When prompted to press enter to boot from cd, do so and the option to repair or install will appear, choosing install will format your drive.
Sep 08, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Bios reset
whats the bios manufacturer
May 11, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer 5630
That's weird. can you check that you have the proper timezone settings under "date/time settings" and that your system is not automatically syncing itself through the "Internet Time" tab?
Oct 29, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
462 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
