Televison & Video Logo
Posted on Jun 19, 2010
Installing a LG Network Blu-ray Disc/DVD Home
I am installing a LG Network Blu-ray Disc/DVD Home Theatre System HB405SU with a LG 42'' 42PQ20 TV. The AM/FM tuners work, HDMI connection to the TV works, but am unable to get the TV audi to play through the home theatre system.
  • jane walke Sep 30, 2013
    we have a Panasonic blu ray disc home theatre sound system Model no SC-BT735
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
832
Points
10
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
3answers
Hi. I have a LG HB966TRW Home Theatre System with a 3D Blu-ray player and 5 wireless speakers. Recently the speakers have stopped coming on when I switch on the system.
NO AVR here right (I can't see what is THERE total)
why not test the (local LG speakers work ??????_??? fails?
3D blu Ray player and 5 wireless speakers model HB966TRW,on something else. the amazon reviews on it are 50%bad
why own it? I ask. and sub is junk grade.
76 page manual.
how are you connecting this to your TV , HDMI or>
if yes did you turn on ARC? as page 21 states
and SIMPLINK too.
or RCA video cables, and sound RCA the TV
so there are 2 ways to connent and HDMI tops list of good.way
so you can test this on 2 TV , HDMI to see which one fails.
or both fail.
or page 38 do the factory reset...
and start again as new day 1 , setups.
at the bottom click english and free manual is here 76pages.
https://www.lg.com/ae/support/manuals?csSalesCode=HB966TRW.BARELLK
Cant get sound from tv to play through theatre system
Did you check your manual? http://www.lg.com/us/support-product/lg-BH6720S#
Sometimes, you need to select your input (tuner, dvd, tv, blu ray, aux,etc.) and then select if this will be an digital or analog input.
2helpful
My Blu-ray DVD MBFH does not work on my Blu-ray player
do you have it hooked up via hdmi to a tv that has hdmi? also make sure you set the output for the dvd/blu ray player to the correct output your using (hdmi 1 or w/e not a passthru or input) also if your using component cables you may have to go to menu on the unit and select that as your outpput get back to me let me now if this helped
4helpful
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
No sound through home theatre with blu ray connected
Make sure that your receiver says optical 1 or 2 on the front display.
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
