Question about Onkyo TX-SR602 Receiver
Onkyo TX-SR702 keeps going into speaker setup mode
I have an Onkyo TX-SR702 (similar to SR602). It's been working for about 3 years. Recently I've experience quite a few times that, while I was watching DVD or listening to music, I suddenly heard a "boom!" and then no audio anymore. After tuning off the receiver and turning it back on, it continues to work.
When it happened again today, I looked at the receiver display, and noticed it has "auto sp setup?". So I ran auto speaker setup, checked all other setup as well. Then after a few minutes while watching DVD, "boom!" happened again. Now it seems it happens more frequently.
Any known issues? I checked all my connections, and they seemed to be fine.
Thanks!
  • rjmeyer659 Jun 29, 2013
    All the speakers check out receiver does this without anything plugged into it or any speakers connected.
  • Anonymous Mar 31, 2014
    How do you reset the Onkyo TX-SR702
    Genius:
  • Onkyo Master
  • 1,550 Answers
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Posted on Apr 14, 2008
Onkyo TX-SR602 only puts sound out through tweeters, not midrange drivers.
Check speakers ‎Crossover circuit instead of SR602 . The speakers ,midrange drivers, may be damaged. Connect a small speakers at least 4 ohms to see if any sound comes out.
Oct 01, 2017 | Onkyo Audio Players & Recorders
My TX-SR702 receiver often displays a 'Dialog
Need to know your source and exactly how that source is connected to the receiver. Also need to know what surround sound mode you are using and whether the program material that drops out is compatible with that decoding format. Might be as simple as changing surround modes when this happens, but you should know that many cable boxes and some disc players routinely drop their digital audio signals from time to time and can give you these symptoms. Best remedy is to call Onkyo tech support with all of your information requested above documented in one place. They can help you troubleshoot while you are in front of your receiver.
For Product Support Team Only:
1-800-229-1687
Hours:
M-F 9am-8pm | Sat-Sun 10am-4pm ET
Jul 24, 2010 | Onkyo TX-SR702 Receiver
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
No speaker sound
I bought6 the rec a year ago and it has no sound a/b switch on front is on a 2 speakers connected
Jan 29, 2010 | Onkyo TX-SR602 Receiver
I've gone through all of the setup procedures, only the front speakers work, nothing from the rears, center, sub or sides. When setting up with the mic, all goes well?????????????? Onkyo TX-SR602. Tried...
Steve,
I would forget the TV for now. I would use another input source to confirm where the problem is. I would hook up a CD or DVD player to it and check that the speakers are working as they should. If they do work, you may have a bad cable from the TV. Or the new TV is not set for surround sound. It may be as simple as selecting the proper decoder from the TV menu.
Dec 04, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR702 remote problem
So what you're saying is you think the receiver is broken because the remote won't turn it on.
Try fresh batteries or another remote that can be programmed for the Onkyo and get back to us.
Apr 12, 2009 | Onkyo TX-SR702 Receiver
Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Jan 06, 2009 | Onkyo TX-SR602 Receiver
Onkyo TX-SR502 AV receiver
this could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Oct 31, 2008 | Onkyo TX-SR602 Receiver
No sound
The unit is in protect mode until then. What needs to be determined is why it takes that long for the system to settle down. Basically, there are circuits built in to prevent faults from causing damage to external devices like speakers. These circuits prevent the output section from turning on until all of these voltages are correct. If you recall from a long time ago, it was common for the speakers to produce a loud pop when the receiver was first turned on. These circuits prevent that (as one example).
This unit should be brought to a service shop as it will require signal tracing to determine the faulty component. This is not likely to be diagnosed remotely through a forum like this.
Good luck and keep us posted.
Dan
Jun 06, 2008 | Onkyo TX-SR702 Receiver
Onkyo TX-SR602 Receiver Logo
391 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
