Question about Maytag EPIC MFW9700S Front Load Washer
F05 on Maytag MFW9700SQ1
Just bought it and it gives me error code F05 on the first run and every run. Try with different cycle, it still gives me F05 after the first 3 to 5 minutes of cycle and the machine just stop working, so I had to press stop two times to drain the water.
What does it mean and how to fix it?
Also noticed that when the water temp should be cold but this machine delivers hot water. I have checked that the water supply is not reversed.
Is this not a reliable washer? Should I just return in to Home Depot and buy another brand like LG?
Any input is appreciated.
  • kayemmdee Jul 04, 2008
    I had this problem shortly after I got my machine. The solution is covered in the owner's manual, but it only worked temporarily for me. Now my machine is having this problem again - I have been living with it by doing two rinse cycles (one with detergent added for a wash cycle and then another with no detergent for a rinse cycle).
    The first time it happened, I had to call customer
    service. The repairman got inside the machine (I think behind the controls) and pushed a reset
    button that fixed things for a long time -- I thought at the time that I
    should remember what he did since it was simple but can't remember now.
    I am going to have to call again to get it fixed.
I have had my epic front loader washer and dryers for 1 year now. I picked them after carefully researching other brands/models and reading many reviews. Epic had the most positive and satisfied reviews/ratings of all at the time.
I have a large house with 6 furnished suites and I do the laundry for all suites weekly, so there is a lot of laundry. The Epic machines have been great, even with some overloading abuse by the cleaning staff.
I did, however, just experience my first problem - the "Control locked problem"
I googled and found this excellent site - and the fix for the problem (hold "cycle end signal" button down 3 seconds). Worked like a charm...
I tend to think that all of the digital front loaders for all brands will have a problem like this once in a while, as they are fairly complex compared to the prior generation of washer/dryers.
However - your problems with your new machine sounds bad - like you may have gotten a lemon.
I bet they would send you a new replacement machine at no charge if you called Maytag... I would try that first before shopping for a different brand/model...
good luck!
Posted on Jun 13, 2008
  • DarcSystems Mar 05, 2011
    I received this error the other day on my Maytag front load washer. It's fairly new, so I was surprised to see errors, especially ones prohibiting the use of the washer. Some research online lead me to the temperature sensor. I inspected the sensor, checked the resistance, and all seemed fine. I ordered a replacement anyway, since it was only 8 bucks. When I went to go swap it in, I noticed a stray wire that looked like it had been cut. There was no visible break anywhere else, so I thought it might be an unused wire. Upon further investigation, I found the other side of it hidden behind a cheap, sharp-edged wire tie. The vibration of the machine, combined with the sharp wire tie, sheared the wire in half. This happened to be the wire for the temp sensor. I soldered it back together, shrink-tubed it, and so far I haven't had any problems.
    So if you're receiving this error code, try popping off the lower panel on the front of your washer, and looking for a broken black wire. Mend it, and problem solved.
How do I fix the error code F05 0n my Zanussi oven
try leaveing off at main cooker switch over nite
Mar 01, 2015 | Zanussi Washing Machines
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
Washer display code F05 what is this code?
the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F05 error code comes on
Water Temperature Sensor Error - Check the Water Temperature Sensor,Heating Element and Element Relay.
If during the water heating step in wash cycle,the water temperature sensor(NTC) value is out of range,or the heating element circuit has failed,the F05 error code will be displayed - Check connections to
the Sensor,Heating Element and Relay.
Apr 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWOEAST912 - Error code F05
Well An F05 is a water temperature sensor error.
This occurs if there is a problem detected during the heating step of the wash cycle.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Element Relay.
But as you says that your washer is only 4 months old so why don't you ask for warranty......
Please post comments if you need more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Whirlpool Washing Machines
Error Code F-05
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Feb 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
F05 on screen
Hi. This is a water temperature sensor issue.
Replace any parts that is malfunctioning or defective.
Oct 04, 2009 | Washing Machines
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
Maytag EPIC MFW9700S Front Load Washer Logo
1,565 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
