Question about Kenmore Elite 45986 Front Load Washer
Kenmore h3 Elite Hot/Cold Water problems
You answered a question I posed the other day about my H3 Elite washer where I'm having a problem where the hot water valve sometimes sticks open. I found that when I select Cold/Cold, the machine initially starts out with cold water for a few seconds but always shifts to hot. Then sometimes, the hot valve won't close and I get an overflow error code (F9). When the washer goes into a rinse mode, it seems to use the cold water inlet just fine.
I checked and found that the model number is 110.44832202. I also have read on a consumer affairs page that other people have reported the same problem. I don't mind replacing parts myself, but I'm not sure which part I should focus on first. Any thoughts?
    Master:
  • 788 Answers
I wouldn't imagine it being a computer problem, computers don't make mistakes like that. I would start with the inlet valve http://www.partselect.com/xq/aspx/Inventory.391478/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 and maybe the inlet valve wiring harness http://www.partselect.com/xq/aspx/Inventory.391563/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 for good measure. Both parts together will run you less than $100 and shouldn't be that difficult to replace. I'm am no Washing Machine expert, I just go by my common sense and Google. The computer http://www.partselect.com/xq/aspx/Inventory.971890/qx/PartDetail.htm?SourceCode=7&ModelNum=110.44832202 is $250+ and like I said I don't think the computer would cause the valve to open slowly and stay open, sounds like the vavle is sticking. Good Luck!
Posted on Apr 14, 2008
Kenmore elite washer h3 has a f5 code flashing. what does it mean?
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Richard Roth
The FixYa Team
Aug 17, 2011 | Kenmore Washing Machines
I have a kenmore elite h3 washer - Bad Water Pump?
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects(located, and mounted on the actual pump)
If the above does not correct the problem replace the pump
Nov 02, 2009 | Kenmore Elite 45986 Front Load Washer
My H3 washer has error code F02.
unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
F and H codes
You'll need to access the drain pump assy & remove any obstructions from within the drain pump. Your pump has a trap that you can unscrew (be mindful of the water) for access.
May 18, 2009 | Kenmore Elite 45986 Front Load Washer
Owner/operations manual, Kenmore Elite
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Jan 24, 2009 | Kenmore 44832 Front Load Washer
Washer Impelling into Hot Water Line
this sounds impossible,hold old is the washer? how long are the hoses to the washer?is it the temp pressure valve on the heater that bursts? can you hear the water draining out the drain pipe, this machine don't go into spin till the water has been drained.
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3
F/DL means the door lock.  If you take the bottom panel off (there are 3 screws), you can reach up and pull down on a lever to release the lock.  Next you need to take off the top of the washer (there are 3 screw on the back).  ONce you have the panel removed, you can see the wires and where they plug in at the back right area.  If you just jiggle them, you can get it to work again.  I am doing this right now until I can get a new computer.  My neighbor has a front loading washer of a different brand and experienced the same problem I am having now.  She is the one who told me how to fix it.
Oct 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
179 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
