Question about Orion STV2763 27" TV
Orion STV2551 27"TV...
Watching TV...screen went black and now only makes fast high pitched beeping sound...no other sound...no picture...any suggestions?
  • jcook7 Apr 27, 2008
    tv picture went off and just has a bussing sound
    Genius:
  • Orion Master
  • 1,635 Answers
The flyback transformer, and some other components may have failed. The main power supply may also be damaged.
It is impossible to know the exact failed parts without trouble shooting the set.
Jerry G.
Posted on Jun 10, 2008
The screan is too dark while I am watching tv
If a conventional picture tube type set it will have a high voltage transformer inside with a focus and "screen" control--in this case the screen needs to be adjusted up slightly.
Adjustment is inside the set so you have to have back off and be careful as high voltage is present when set is on (need it on to adjust the screen control just up a tiny bit).
Oct 21, 2012 | Orion STV2763 27" TV
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Sylvania SRT2232S Powers On, No Picture, High Frequency squeal
Hello there. I'm sorry to say that it sounds as if the element that actually energizes your screen is bad. It is most likely overheating. or quite poosible the power converter lost a resistor or 2.
Nov 27, 2008 | Sylvania SRT2232S 32" TV
Black screen
you mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Sep 14, 2008 | Orion1934 19" TV
Black screen but have sound
If it is not a hardware problem, it is most likely the Closed Captioning system.
If you can still see the on-screen menu, go into your TV's menus and disable Closed Captioning.
May 14, 2008 | Toshiba 36AX60 36" TV
High pitch sound comming from tv!
The horizontal transistor and the flyback are damaged
Apr 24, 2008 | Samsung TX-P3264 32" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
RCA Telivision
The beeping sound is caused by the power supply trying to turn the set on then off. Your failure is a bad high voltage transformer and subsequent failure of the horizontal output transistor. Probably not a cost effective repair.
Mar 01, 2008 | Televison & Video
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
Orion STV2763 27" TV Logo
302 people viewed this question
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
