Question about Irons
Oliso auto lift iron
Lifts, won't heat, can't see how to get housing apart.
  • 1 more comment
  • charmingchar May 17, 2008
    Lifts, green light blinks, but it does not get hot.
    Have tried several outlet plugs to double check.
    No luck. Only 6 months old.
  • qksand Sep 04, 2008
    Have used Oliso for 2 years and it quit heating just yesterday. Any trouble shooting suggestions ?
  • Anonymous Mar 31, 2009
    Same problem. Lights, camera, but no action.
    It just stopped heating up
  • 30 Answers
SOURCE: steam iron
time for a new iron, safety first , you will be surprised at what you can get on sale these days
Posted on Sep 03, 2008
SOURCE: Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Posted on Sep 21, 2008
heatman101
  • 43501 Answers
SOURCE: My oliso iron is not heating up yet all the lights
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: iron leaks , lift stuck in up position
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
baraquielnar
  • 247 Answers
SOURCE: The auto shut off on my new iron has stopped it
it has a adjusment try to adjust by rotate it to clockwise it is located inside of your iron use a screw driver to adjust then observe unit. if not u purchase new unit.
Posted on Feb 17, 2011
My oliso tg1250 has stopped lifting,what can I do??
Call 1-800-899-5157 - or - email customerservice@oliso.com
They made this and they are the experts.
  • THeT
    Apr 06, 2017 | Oliso Irons
    I got this iron for christmas, it shot steam 2 times and thats all. I had it set on cotton, linen. I used reg bottled water, should i use tap and why no shots of steam.
    take it back for a warranty exchange after you check that the thermostat setting is on steam
    distilled water is recommended for irons
    bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
    Jan 02, 2016 | Oliso TG-1100 Continuous & Burst of Steam...
    I plugged my max 110 V Oliso iron into our house's only 220 V outlet. Smoke is being emitted and it is unusable (The iron, not iron). Can someone please tell me how to fix it?
    are you saying that the iron works with 110 volts and you plugged it in a 220 volts outlet??? if so then the voltage is to high for the iron (luckily it didn't get burnt) but all you need to do is plug it into a 110 volt outlet
    Jun 23, 2015 | Oliso TG-1000 Iron
    Oliso auto lift not retracting
    Its can be your switch inside it so you have to strip it and cut it out its a small its like a resistor you can brigde the wires its also fine or you can go and buy a new one and put it again but you will need to solder it back
    Sep 12, 2014 | Irons
    My iron does not heat up
    The most likely cause is a faulty temperature sensor. The Iron is most likely shutting itself off because it believes that it is already at the correct heat. The less likely scenario would be a faulty heating element. In either case you will not be able to fix this yourself.
    Check that the Iron is correctly plugged into a working outlet as that often tends to be the solution we all miss.
    Mar 07, 2011 | Oliso TG1050 Iron with Auto Shutoff
    Iron leaks , lift stuck in up position
    heatman101
    Jun 12, 2010 | Oliso TG1100 Iron with Auto Shutoff
    My oliso iron is not heating up yet all the lights go on when I plug it in and turn it on.
    heatman101
    Nov 30, 2009 | Oliso TG-1000 Iron
    Irons Logo
    206 people viewed this question
    Top Irons Experts
    Are you an Iron Expert? Answer questions, earn points and help others
