We are not getting reception from our Magnavox Model # PR1901 C127. It is not responding to the remote or the power button, although the cable box is on. It is also not responding when plugged into the power soure in stead of the cable box. We had been experiencing what Time Warner Cable described as Micro Blocking on our screen for the previous month. They were unsuccessful in eliminating this problem.Is our TV now "Dead"
SOURCE: i purchased a SANYO-DP46848 42"HDTV.
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
Posted on Jul 28, 2008
SOURCE: HDMI connectivity
I have the SA8300HDC STB from Time Warner. I get this error from my DVD recorder, not from my HDMI connection. I've read that the error is due to copy protection. The only solution I've read about has to do with a new Samsung Set-top box from TWC. Funny this copy protection error didn't ever come up with my old VCR connection to the HDTV. TWC apparently told a lot of people that the problem would be solved by a software update from TWC in October 2007 & then in December 2007. Guess TWC isn't sure what the problem is but everyone who has mentioned this Samsung cable box has reported success with their HDMI connection.
Posted on Dec 11, 2008
ladywinn
  • 5138 Answers
SOURCE: TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Posted on Dec 18, 2008
SOURCE: codes to make my Time warner remote control the tv
Here's the list from Time Warner
http://www.timewarnercable.com/Carolinas/site.faqs/Equipmenta/Remotes/Digital-Remote-TV-Codes
Posted on Mar 22, 2009
  • 33 Answers
SOURCE: There is sound but no picture. I called the Time Warner Cable.
Yes the problem is in the tv. If you have no onscreen display and good sound it is highly likely that there is no high voltage. If there is no high voltage the unit can either be in shut down mode or it could be shorted out in one of the power supplies. A test can be performed to determine if there is high voltage or not which will tell you which circuits to trouble shoot if you want to try repairing it yourself.
The quick test to determine if there is high voltage is simple. If you want to know how let me know and I can help. But in any case if there is no onscreen display and there is good sound, it is highly unlikely there are any quick fix options, as the problems are usually in the power supply, high voltage, convergence, or possibly even the light tubes. It would require an experienced technician to narrow it down and repair the problem.
Posted on Apr 28, 2009
I have a magnavox DTV Digital to Analog converter box model TB110MW9 I have lost the remote I do have a universal ONN remote model ONA12AV058 The box is not powered on you need the remote to power on the...
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Check the two links sited here and see to get all setup codes to Magnavox converter. Chekc with that codes. You might have to check more than one code.
Apr 13, 2014 | Televison & Video
MAGNAVOX UNIVERSAL REMOTE
hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
Mar 29, 2008 | Philips Magnavox Learning Universal Remote
My magnavox pr1901 C121 TV will not turn on.
Check and replace faulty component/s in the main power regulator circuit.
Aug 21, 2012 | RCA Televison & Video
Need code to an rca universl remote to control a magnavox tv
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Magnavox TV Codes: 006, 007, 010, 013, 016
Sep 21, 2011 | RCA Computers & Internet
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I need the TV code for my RCA universal remote for a magnavox
You actually don't need codes to program your remote to your tv! If you want them I can get you them but here is how to do it without codes:
Feb 08, 2010 | RCA Televison & Video
I have a 27" magnavox tv and it's on standby and i don't have the remote to turn it on is there any way i can get it to turn back on without the remote or can i get a a universal remote or anything please...
if there is any buttons on tv some tvs have cover over then on frount or side of any press ch.up or ch.down
is no buttons can be seen you can find remote on chylse hyde and son web site (CHS) tou will need make and model of tv
hope this helps
MERRY CHRISTMAS
Dec 14, 2009 | Philips Magnavox 27MS343S 27" TV
Big button remote rcr 4258
does not have all the codes for every product,
Please give me the model # for the cable box -scientific Atlanta and the model # for Magnavox T.V.
also goto www.replacementremotes.com (336)969-1842
They will find you REPLACEMENT remote control CODES, not remote control
Apr 12, 2008 | RCA Universal Remote Control
RCA Universal Remote Control Code
sony code is 002
Dec 16, 2007 | RCA 244889 Remote Control
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
