Question about Kenmore Elite HE4 Electric Dryer
Dryer appears broken, heard LOUD sound from other room (broken belt?)
Had a really heavy load of wet clothes put in dryer, after some time running, we heard a loud noise while we were watching tv. Later checked on the clothes and they were still wet. Dryer panel lights up and when you push start it makes a sound like a electronic click to turn on, but doesn't do anything.
I know nothing about dryers, could we have busted a belt or something?
  • cbushsbush Apr 15, 2008
    Problem Solved!, I am so proud of myself. I started taking off all the screws in back and removed the top and saw the little tiny thin belt that turns the drum. I pictured it to be much bigger; no wonder it snapped. I bought a replacement one for $18+ and got a copy of the diagram of all the internal pieces. I only had to problems. Diagrams don't show you how to do anything, so I wasn't sure how to get the belt around the drum. Turns out the silver piece on the back of the drum covers a big hole (where heat comes in?) and if you pull that back you can get the belt inside the drum. Once you do that, you can fish it past the edge of the drum and then just rotate the drum until you get it around the whole thing. At first I thought the belt was too big, because I wasn't sure how to configure it around the spring wheel and the spindle thing on the motor. It finally dawned on me how to put it in place (can't draw diagram here) and whola, back in business.
    There's no greater feeling than being able to fix something stupid you did for under $20.
  • Anonymous Dec 23, 2008
    I had the same problem, except I thought there was even more wrong with the dryer. When I tried starting it, the dryer just clicked and would not start. After tearing the dryer apart I noticed the belt lying there broken. After looking at the service tech manual which was kept inside the dryer compartment, I realized there was a switch which only activated when the belt was putting pressure on the pulley. Now all I need to is find a new belt and install it, and maybe not fill the dryer too full so as not to break the belt
Gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Posted on Sep 15, 2008
Dryer is making loud jerking noise
bad or broken belt, not sure if its ever been serviced ?
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
Jan 05, 2015 | Dryers
Dryer makes a loud scweaking sound
THAT HAPPENS AS DRYERS GET OLDER, NORMALLY ITS JUST NEEDING THE BELT REPLACED, IF YOUR PUTTING IN HEAVY LOADS THE BELT IS HAVING A HARD TIME TURNING THE DRUM, AND EVENTUALLY IT WILL JUST QUIT OR BURN UP THE MOTOR IN IT IF YOU DONT GET IT FIXED.
Dec 31, 2011 | Televison & Video
I have a Kenmore Elite Dryer Model 110.66992500 that will not start. When the start button is pushed, it only makes a click. During the last use, the dryer was working fine then all of a sudden while...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 01, 2011 | Kenmore Elite HE4 Electric Dryer
Drum will turn empty but will not turn with heavy wet clothes in dryer. Is it a bad motor?
no, most likely, especially if it sounds right, it is a bad belt. The reason why i say if it sounds right is because the machine don't know the difference. if it was the motor you would hear a really loud hum before it stopped and then maybe it would start back up and hum some more. if your clothes are really heavy like dripping on your feet heavy. then you have a problem with your washer. Probably a transmission.
Jun 27, 2010 | Speed Queen AGS28AWF Gas Dryer
Dryer was running with full load of clothes. Heard a loud pop twice, ran back to the laundry room and smelled like something burning. Turned dryer off, and now it won't start back. Also, the very top of...
Well it sounds like a sound I have heard... forgetting that I had a cigarette lighter in my pocket and having it explode from the heat in the dryer. But you say you heard two loud pops?
Once everything cools down, check again and report back... does the dryer not turn on at all? Does the light come on when you open the door? Does it buzz when you push the start button? Stuff like that.
Jul 27, 2009 | GE DBXR463EDWW Electric Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Kenmore 80 Series Heavy Duty Dryer won't work
hi thanks for the question the belt has probably broken there should be a bottom panel use screw driver to pry the front on each side pry outwards remove panel now you should see a broken belt replace thanks the appliance dod
Sep 25, 2008 | Kenmore 63942 Dryer
Kenmore Elite HE4 Electric Dryer Logo
155 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
