Question about Rane Serato Scratch Live Computer DJ Solution (Macintosh and Windows) Sound Card
Serato How do you get the program from going in reverse? The tables are playing straight but the program is going in reverse.
  • 2 more comments
  • sketelrice Sep 05, 2008
    when i hook up the serato one side plays in reverse and the other plays forwards why is that so all of a sudden.
  • jackbluff Oct 02, 2008
    both tables on the software are spinning backwards all of a sudden, not a clue why!
  • DJSDSMV Oct 11, 2008
    same thing happens to me.  sometimes i take the whole head case off and then put it back into the turntable and it works again.  sometimes it's dust.  it's real annoying.  i'm thinking of going to CDJs.
  • imthinhle Nov 01, 2008
    I have the same problem too. I was spinning last night @ a party and it started going in reverse. I took out the headshells wiped them down and kept cleaning for dust then it worked for a bit, but the problem kept coming back. One side was good the other side was going in reverse.
Give your headshells/needles a good cleaning. I had the same problem, did that, haven't had it since.
Posted on Apr 17, 2009
Did you make sure that the rca cables are in the correct left and right inputs because if you reverse them it will not read the signal correctly
Posted on Apr 16, 2008
How do I make adjustments on my ridged r4512 table saw?
The carriage under the table is held to the underside of the table with several bolts or screws. Loosen those screws.
Raise the blade and clamp a stiff metal straight edge to the side of the blade. Use a carbide blade and clamp the straight edge to the sides of the teeth. Move the carriage around until the straight edge is parallel with the miter gauge slots, then tighten the bolts.
Oct 12, 2014 | Ridgid Saws
How to pull stator out of gearbox to change front bearing
1) Remove brushes
2) Remove 4 screws holding field assembly to the saw frame
3) Pull field off
4) The armature will then pull straight out (It may take some work to wiggle the bearing loose, but it will pull straight out)
5) Press bad bearing off & replace
6) Reverse process to reinstall
May 24, 2014 | Bosch 4000 - 07 Electric Table Saws
Auto reverse
You do not list brand and model but it is typical that the belt replacement is missing the mark in that the reel rotation sensor is not detecting rotation of the reel table and therefore trying to go the other way. The reels have to be turning in play mode. If they do not auto stop or the reverse function thinks the tape is at end.
Apr 15, 2014 | Audio Players & Recorders
Callpilot will not answer calls
Check AA/LINES
i.e. Line 1 is 001 in programming
line 5 to 8 on older systems is 025 to 028
If you recorded Grtg # 1 then go to Table 1 and make Morn etc play #1
Then check AA/lines and make sure AA = Y and Table = 1 and Ring count set to 0 (or 2 if caller id at site).
Reboot system perhaps.
Nov 24, 2012 | NorStar CallPilot 100
Serato does not recognise my technics turntable. The turntable is on and turning well but no response from serato. the arms in the serato do not move...help?
serato is a software to be used with an external soundcard it doesnt care what turntables you have. u have to a rane mixer or one that is serato capable in order to use it. then you have to go and link and sync your time codes
May 26, 2011 | Technics SL-1200M3D Turntable
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
Can we make it so the phone can receive calls but not make out going calls?
You can, but you need access to Installer level programming. I'm not going to give you detailed instructions here, because any fool can do the reverse and UNrestrict a phone with the same instructions, but system program 500 and 501 sets day and night restrictions on a phone. Setting the COS to 7 lets the phone dial 0, intercom, and, by programming, System speed dial numbers.
COS 8 allows Operator only (internal operator).
By building tables, you can actually program different restrictions and exceptions for COS 2-6. There's a fairly comprehensive discussion in the Panasonic Features Manual of your TD 816/1232 manual.
Carl
Feb 18, 2011 | Panasonic KX-T7431 Corded Phone
I am experiencing similiar problems. Was gettin a table error. So I craked into it and removed a couple cds which were jammed. Now the table error is gone but all 300 cds will only play the first half of...
Hello,if the spindle table is bent "this is the platter on the motor that the disc sits on" it will have problems reading the outside of the disc,which is where the later songs are.Check to see if there is extensive disc wobble during playback,sometimes you can slightly bend the table to near straight,other times you need to replace the motor.
Jan 08, 2011 | Sony CDP-CX300 CD Player
Im having problems programing my sansui flat screen tv when i program my rcr311b universal remote it works up untill the point when the tv turns off after pressing the play button and releasing the reverse...
first wat are u trying to do,,,,,,in mind....wat way,,,,,to do wat....try going to get thing that can remote w/remote to do......reverse the plan of mind,,,,
Aug 27, 2010 | RCA RCR311B Remote Control
Open Questions:
Computers & Internet Logo
725 people viewed this question
Top Rane Computers & Internet Experts
David Payne
David Payne
Are you a Rane Computer and Internet Expert? Answer questions, earn points and help others
