As DrWho_64 mentioned, you've probably activated the logon prompt somehow. But since you tried jonesspammai's method and didn't work, It seems that your user account's password has been set. So all you have to do is perform password reset. Here's how to reset your password:
Hope you'll have it resolved soon :-)
Sounds to me like you activated the Windows Dragon. Yes, it actually called Dragon. Its the enterprise or domain logon prompt. The only time I've seen this happen to people is when they try to install Windows XP Pro over a Windows XP Home installation or they attempt to repair a faulting installation of Home with an XP Pro disc.
Is this your situation? If it is, it's ok and we can make Windows go back to the User Icons instead of the Network Logon prompt which you now have (at least thats what it sounds like you're looking at).
So, first question I need to have answered is this: Are you using the Dell discs to reinstall from or are you using an XP install disc? The Dell discs that came with your computer are the ones you should be using.
Either way, changing the way you login is fairly simple.
First, you will need to login as the Administrator or as a user with administrator privileges, in order to make this change.
This can be completed in 4 easy steps:
Just follow these simple steps and you'll be back to logging on with your friendly Windows Welcome screen!
Hope this answered your question. If you have any other issues, drop me a line and I'll see what I can do to get you back on track!
GL!
for which operating system ????
Windows XP users
Change password
Note: Windows XP Home users can only change the Administrator password through Safe Mode Windows Vista and 7 users Change username
Change password
Windows 2000 users
Change password
Microsoft Windows 2000 users can change their username by pressing CTRL + ALT + DEL while in Windows to open the Windows Security window. From this window click the "Change Password" button
Enter your old password and the new password you wish to use.
Change username
In order to change the username of an account on Windows XP you will need to have an account with Administrator rights. If you're logged in as Administrator or have an account with Administrator rights, follow the below steps.
hope this helps
