SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
SOURCE: I am looking for crisper bins for a F & P N500B fridge
Here is a parts store you can call 6 days a week and order any part you need I did not find that model listed but you can talk and find the number. here it is and hope this helps thanks for using fix-ya.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=E522B
SOURCE: fisher & paykel refridgerator E522
yes u can buy it from Fnd P call 1800650590 they wil send it out to u ,
SOURCE: Fridge compartment not cooling. Freezer
Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
SOURCE: Hi, I have a fisher
I had the same problem. my freezer was set too cold so the water inlet was freezing. what I did was blew a hairdryer into the ice making section for a couple minutes, this seemed to melt the block, then tested that it was clear by forcing the ice tray through a cycle. you then need to set your freezer warmer - I find setting it 2 bars from the warmest setting keeps stuff frozen and the ice coming :) hope this helps!!
