Can I order a disk to format my compaq computer
  • 42 Answers
If what you want to do is order discs to format your computer and reinstall Windows, then yes. Call 1 800 HP INVENT and let them know that you'd like to order a set of recovery discs. They'll probably want your serial number which is usually located on the back of the computer.
Posted on Apr 14, 2008
Is there any software for boot manager?, because i dont have a hard drive for re-installing my HP compaq nc6220?
Hi, You need a Windows operating system CD or system restore CD that come with the computer. You need to format the hard drive and install windows. After that is complete you need to install all the drivers in order the lan controller, audio, and display will work properly. Get back to us if this information helps you solve the problem.
Jul 13, 2011 | Computers & Internet
Formatted hard drive need drivers to install windows xp pro
here is what you need:
Feb 17, 2011 | HP Compaq Presario C304NR Notebook
Problem loading os on compaq evo n610c
Make sure you start by deleting the old partition, and formatting C:. If it still locks up after that, then your hard drive is bad.
Nov 21, 2009 | Compaq Evo N610C Notebook
(A) Try interrupting the boot sequence and telling the computer to boot using the last known good configuration. Here's how: 1) Turn the computer on, and press F8 repeatedly until the boot options menu appears (the menu items include "Start Windows Normally," "Use Last Known Good Configuration," etc.). Use the arrow keys to select "Last Known Good Configuration" and press ENTER. The computer should boot correctly.
if it dont this is the procedure given below to format the whole operating sys 1) Put the CD in the CD drive and turn the computer on. 2) As the computer begins to turn on, you should see the message "Press __ to enter setup" (it's usually F1, F2, or F4 - models vary). Press that key.
3) You should then see the Setup screen for the BIOS ("Built-In Operating System") - using the arrows, find the "boot disk priority" settings and select your CD Drive as the first priority.
4) Exit setup, saving changes (usually by pressing F10). The computer should then boot normally using the CD.
Jun 18, 2009 | HP Compaq Presario v3000z Notebook
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
Cant install recovery disks after a hard drive reformat!
the recovery disk is designed to repair or restore a system to its previous factory condition and is not a full installation. the formating of your hdd would have erased all the data required for this process to be completed. you can try a recovery utility that may be able to help you at this link. the disk might not have been saved in an .iso format to tell the computer to run it before starting an OS. if this disk is recognized and runs on your system then you will need to attempt a recovery, which is unlikely since the drive has allready been formated many necessary system files may not be able to be restored. at this point a complete new install will be necessary.
Good Luck!
Mar 12, 2009 | HP Compaq Presario C304NR Notebook
I couldn't install windows xp in Compaq cq45 112au
Try using an win 98 startup disk on floppy and start your computer with disk in.Let it finish loading the drivers and then type in fdisk erase your partition and then make a new one. then restart the computer with floppy still in then this time type in format c:/ and format the drive after it is done then you can install win xp.But you need to repartition your hard drive and then format after that to get xp to install Oh yeah when you go to fdisk allow large drive usage
Jan 25, 2009 | Computers & Internet
Re-formatting the Hard Disk
It sound like you have a Sata hard drive that needs Drivers an order to access the drive, using a floppy and F6 at windows setup. send me more info on your laptop model and make.
Oct 23, 2008 | HP Compaq Presario V6000T Notebook
Compaq restore cd
Hi mithz.
I'm not you people.
(Please keep track of the user who you ask a question too).
When you installed windows 2000, (If you formatted the entire drive during install), you might have taken out the small partition that holds data for a system restore. No version of windows likes
you going backwards. In order for you're system restore CD's to work you'll need to format the hard disk drive. Windows will not install if Windows 2000 is found on the drive. The fastest way to get Windows 2000 off the drive without deleting any other partitions Compaq installed would be to go to the hard disk drives manufacture's site & download their setup tools/utilities. You'll be able to creat a bootable floppy disk that will function in a dos-like mode out side of windows. You'll be able to format the Windows 2000 partition. Once that is done you will be able to incert the restore CD (s) & install Compaqs windows XP.
You may need to pull the drive in order to see who made the drive. EX; Seagate, Smsung, Maxtor ect. Here is the link for Seagate.
Every manufacture has similar bootable floppy software.
Read the instruction provided by the manufacture on how to create the floppy disk & how to run it.
Good Luck!
Jul 15, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
