Question about Toshiba Satellite A100-S8111TD Notebook
Display not coming on..
I have a toshiba satellite A100-036 laptop...wen im switching it on the display is not coming.it was fine till yest...nothing was wrong..could it be a virus?or cud some insect get in n bite off the wires or sthing like that??wat shud i be going??i stay in Kerala, India and my warranty gets over next month...
    Genius:
  • 1,554 Answers
Try removing the battery and power up.
Posted on Apr 14, 2008
Toshiba Satellite Laptop wont boot up
does it shows the flash screen which displays *********** board? if yes then you can check by installing a fresh copy of windows and if nothing comes on the screen then you may have defective mother board.another thing if *********** board is fine and you find that your system is not installing the OS,you need to zero-fill your hard drive then,coz you may have a corrupted hard drive.
Apr 07, 2012 | Toshiba Satellite L355D-S7901 Series...
Crash blue screen
Toshiba Satellite A665 Have Problem Wen i Am Using Internet Then Its Com Blue Screen And Memory Er-or Coming And Then Go To Restart
Jan 20, 2012 | Toshiba Satellite A665-S6070 Notebook
Wen i conect my compuer only de power light comes on.day before i working normal and i switch off normal.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Toshiba Satellite 1805-S204 Notebook
Screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Feb 22, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Screen not functioning
you display might have got disconnected from its port ...
Sep 14, 2008 | Toshiba Satellite M115-S3094 Notebook
Memory upgrade
if the problem sounds as it seems, you need to take the ram that you put in out, see if it turns on. if not, you may need to replace the battery. the laptop will not work on the charger itself, that ay be the problem.
Mar 22, 2008 | Toshiba Satellite L10 Notebook
Toshiba satellite A100 Monitor problem
LCD issue it needs repair..call tosh if your laptop is still in warranty
Feb 01, 2008 | Toshiba Satellite A100-ST3211 Notebook
Blank screen once in a while
over heating get a labtop cooler pad 1st see if it does it agian get heat out of it 15 bucks on ebay 2500 rpm one never set it on a bed
Jan 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M45-S351 PC Notebook
cutemah, Is your cd/dvd internal or usb? Have you tried to login using safemode? When the first Toshiba screen appears press the F8 key. Choose safe mode. Since you say the cd/dvd isn't being recognized that too may be the problem. Try removing the cd/dvd player and see if the machine starts. Is the error code only 0x57 or is there more? It is sounding more hardware related than software related. What program are you using to format the hard drive? Send me a little more information please. Let me know what happens. Good Luck, Tim
Mar 14, 2007 | Toshiba Satellite M45-S351 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
105 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
