Question about Intel D850MV Motherboard
Any other advice?
Thank you for attempting to find a solution to my problem. Unfortunately, I was not able to find the correct settings to allow me to boot from usbkey. I added additional information to my problem. Can you think of anything else to help me?
  • Cloyne Nov 18, 2008
    My USB KEY is bootable because I was able to boot my laptop from it. The problem seems more that I can't seem to find the correct combination in the BIOS to read the USB key at start up. It always boots from Hard Disk even with USB as first boot device.
  • 42 Answers
this trick will allow u to use ur usb stick as a key to boot into windows . if someone tries to start the
computer without the usb stick , it will display boot errors. before we begin , let me tell u that playing
with the bios and boot files of ur computer may result in u not being able to boot into ur windows partition ; so continue at ur own risk!
step1: unhide hidden and protected files: go to tools > options > view , check show hidden files and uncheck hide protected system files
step2: from the drive where windows is installed copy the files boot.ini,ntdlr and to ur usb stick
step3: now we need to go into ur bios , so restart and keep jabbing (F8 or DEL) as soon as the pc starts
step4: once the bios , enable usb drive as the first boot device u might have to enable usb legacy support on older bioses
step5: restart ur pc if all goes well , u should be able to log into windows if not, then unplug the usb stick , return to the bios and change the first boot device to ur hard disk drive and repeat the steps above
step6: once u r logged into windows , go to ur windows drive and rename boot.ini to boot.bak
step7: to check if u have setup everything correctly , eject usb and reboot the pc u should get error message on the screen such as "invalid boot.ini" or " windows could not start "
step8:incase windows does not load , use ur windows recovery disk by followin the steps at
Posted on Nov 18, 2008
Tm800a620mrd I have tried to reset my time. I go to settings. Hit time and date. Message comes up Unfortunately setting has stopped. I have tried this for almost a week.
You've posted this in the watch forum - what you have is an Android tablet. Suggest you post it in the correct category to get advice.
Sep 30, 2017 | Watches
Forgot email and cant unlock the tablet
try to search for hard reset for your model with model no..
Dec 22, 2013 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Unfortunately the freezer side of the Whirlpool Fridge Ice & Water Filter Freezer has stopped working!
Look for the possibility that there is power on the refrigerator. The door gasket must be tight that cooled air isn't going outside. Check the temperature control, be sure it is in correct setting. Also the defrost timer setting, set it to the correct settings.
Be sure also that the freezer has no pinhole otherwise it is cause by a sharp object punctured the evaporator.
Thank you for asking.
Sep 01, 2011 | Refrigerators
Flame went out. Attempts to relight allow the pilot to light but will not remain engaged to allow setting to on position.
Hello genepage,
I understand that you are having a problem keeping your hot water tank pilot lit. I have wrote a tip that explains what the problem is and how to correct it you just need to follow the link to this tip. Click here to go to the tip!
Thank you for choosing
May 03, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Trying to unlock my Nokia 1600 i get not allowed message
try the following
without SIM inside the phone.
After entering the security code, are you getting any message on your phone as "Cannot Undo Restriction" or "Not Allowed".
Note - You only get 5 attempts to unlock the security code.
The message "Can Not undo Restriction" or "Not Allowed" means that an incorrect code has been entered 5 times or more, before entering the generated correct code generated. This means that even a correct code will not unlock your phone. Unfortunately, your phone can now only be unlocked using a direct cable method, your local market unlocker should be able to help you out.
Jun 06, 2010 | Nokia 1600 Cellular Phone
I dropped my lens and broke a plastic piece off the bayonet mount
Unfortunately, Nikon does not incorporate better built into the kit lens. If the break is merely cosmetics, my advice is to try to repair it or live with it. Most times, the repair cost may exceed the $100-$125 [used price] of the 55-200mm lens.
Apr 06, 2010 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Can't get to onscreen display for auto set up
on page 15 of user manual there's info about it. Unfortunately, there is no OSD on HDMI connection.
Best regards!
Nov 16, 2008 | Yamaha RX-V463 Receiver
My daughter is uaable to send and and receive mail using Windows Live Mail however you is able to send and receive on Outlook Express using the same settings. I get Error message 0x0x800CCC0F(Connection...
1. Dissable any firewall you may have running ( windows firewall , norton firewall , macafee firewall )
2. Attempt to email again using your outlook express.
3. If you no longer receive the error message turn the firewall back on and configure it to allow
4. Configure the firewall to allow outlook express to be able to connect to the internet under all circumstances.
You may need to consult your firewalls documentation to configure it correctly.
Or you may ask one of our Experts.
You will need to explain to them what firewall you actually have.
Thank you for choosing FixYa.
Sep 19, 2008 | Computers & Internet
Maytag advanced cooking system
I attempted to locate a user's manual for you but your model number came back as invalid, please recheck your model number, and follow the link that I provided. This will allow you to download a manual for your range.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Jun 17, 2008 | Maytag MER5775Q Electric Kitchen Range
Intel D850MV Motherboard Logo
168 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
