Question about IBM ThinkPad T23 2647 Notebook
Does not power on
When you push the power on button, pc won't start or power up.
  • 813 Answers
Hi friend
chk your power supply it has been ded or not working
chk your power cable
Posted on Apr 14, 2008
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
It won't power up. I have tried all of the "normal" fixes.
Does it start , lights come on and shutdown in a few seconds? Can you describe what happens when you push the on/off button. BOTH? Do you have them on a battery backup/surge protector? Need more info.
Dec 09, 2012 | Acer Power FH PC Desktop
My computer won't start up
Sounds like you need to have a local PC repair shop test your Power Supply.
Tallon41
Sep 18, 2012 | HP Computers & Internet
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
Y acer 3100 series won't start
first, check your power adapter. Confirm if it is working. If the adapter is working, it means your acer has developed a power fault.
I would suggest you take it to a technician because it is a bit technical to fix laptop power faults.
Good luck.
Jan 04, 2012 | Acer Computers & Internet
The power button does not stay on. i can push it & it tries to start but then stops. Was working on computer & it just turned off started it once & within 5 min it went off again &...
the push button has a spring in it and is not releasing when you push it so it stays on and pops off take an exacto knife and go around the edges clean it off see if this helps if now get a new button replacement if not just get a new box they are cheap on eBay..good luck mine repaired with the clean up. if your handy you can take it apart something is stopping the actuator on the pb...
Oct 25, 2011 | E-Machines eMachines Desktop PC
Dear sir! my dell optiplex gx 150 won't start when i press the power button but power supply will be start and pc can't give any beep ?
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
Jun 22, 2011 | Dell OptiPlex GX280 PC Desktop
IBM ThinkPad T23 2647 Notebook Logo
48 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
