Faulty JVC PLASMA DISPLAY MONITOR model number GM-P420E Left side has a black line approx' 6-8cm wide from top through to bottom. How can this be repaired?
Does it have a buffer board? If so, check the IC burnt on the buffer board. If bad, replace the buffer board. Check the flexible connector exactly below or above the black line. Is it inserted correctly? Does it have an IC on the flexible cable? Is it brunt? If so, you need a panel. If the buffer board is OK, then you will need a panel
Posted on Apr 14, 2008
TH-58PZ750U Panasonic Plasma TV, problem a black bar, from the top left side of the screen (one foot from the left side), approximately 3" wide extends from the top of the screen to the middle of the...
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Faulty screen-shots to plasma TVs are given. You can compare it to that of your TVs' and make sure about the fault. Details too is there.
Oct 12, 2013 | Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Two vertical black lines on the screen of my ps50b430
Unless someone played with the TV and disconnected the plasma display from the address buffer boards that go under the screen the prospects aren't good.
All vertical lines in all plasma TVs I have seen are operated by chips embedded in the fabric of the display as well.
When they fail they'd either short or burn open.
In the first case they'd prevent the TV from coming up, in the second they'd typically manifest as either black or a random color vertical line like you have.
This is not repairable...sorry.
The odds of this being something else is fairly minimal in my opinion.
Please don't kill the messenger...
bobby @ coppelltvrepair . com
Aug 25, 2012 | Televison & Video
I have a thin yellow line running from top to bottom about 10 inches from the left side, what's wrong?
This can be due to faulty LCD driver IC which creates a noise bar and is shown. Check the cords to the display and also the ground connection to the display. If this is good then the IC can be faulty.
Dec 15, 2011 | Hanns.G Corporation JW-199DPB 19" LCD...
I have a permanent dark/black 4.5" wide vertical line on left side of plasma TV. It seems as if it is 4:3 display mode on left side only. Any help would greatly be appreciated. I have no problem changing...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
Jun 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
I have lost my remote for JVC TV GM-V42S. Where can I get one? Thx Rod
I contacted JVC professional to find out the model number for my JVC GM-V42E. Once you have the model number, contact JVC and order a new one or google the product number and try using websites that are dedicated to providing remote controls, I was able to get one from avukltd.com a little cheaper and more quickly than JVC said they would have the product in stock.
I also found the remote control product number on the bottom of the plasma screen.
Apr 05, 2010 | JVC GM-V42 42 in. Plasma Television
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
JVC GM-P420E Plasma no video green screen
the problem is with the micro processor on the back of the fx-1169a board (gm-p420ug) this is the board the inputs connect to . yours may be a diffrent p/n due to yours bein a "e" extention model. to repair this problem you need to remove the processor from the socket, remove the socket from the board and solder the processor onto the board. the processor is ic002 on the back side the problem is thermal in nature due to cold solder joints on the socket. i have fixed this problem many times by using this method.
Sep 09, 2007 | JVC GM-P420UG 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
