Computers & Internet Logo
A
Anonymous Posted on Jun 19, 2010
I logged onto your belkin page 192.168.2.1 trying to set up a password for my router I may have messed up something I went to the login page and typed in a password it then said I needed to chose a password I chose one and now I have no wireless connection off my router and it wont let me go back to your 192.168.2.1 page on the internet
Anonymous
Level 3:
Guru:
  • Master 1,705 Answers
  • Posted on Jun 19, 2010
Anonymous
Master
Level 3:
Guru:
Answers
1705
Questions
Helped
402740
Points
5112
There should be a small recessed button on the back of the router. Youi'll probably need a biro or something similar, press the button in and hold it in for 10 seconds.
This should reset the router to the factory default. You should then be able to go through the setup procedure again.
8helpful
What is the password for a belkin router F9K1123v2
If you are asking what the default credentials are to log into the admin panel of the router, then the options are below.
Default usernames: admin, Admin, [blank]
Default passwords: admin, password, [blank]
If you are asking for the Wi-Fi password, that is unique to the user who initially set it up. You can reset the router but following the manufacturer instructions and holding the reset button down in the back. This will erase all settings on the router.
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
I am trying to find out what my WPA key is for my Belkin G wireless Model# F5D7234-4. The PS3 Network went down and now I have to re-enter it into the system and I don't remember what it is
Type 192.168.2.1 into your web browser's address bar. If you have not changed the default login, you should be able to click the submit button and log into the router. If it has been changed, type in your login and password information. In your router's menus under the wireless security settings you should be able to find your network's password. If it is all starred out you can put in a different password and use that for your network. Unfortunately, you then have to change this information on every device that logs into your network. Good luck.
2answers
Forgot my password for my Belkin router that ive had for one year now. Trying to connect to wi fi for my daughters new ipod touch...having problems. Please help.
You can restore the Belkin back to the default settings by -
Power off the Belkin, press and hold the RESET button with a paperclip then insert the power cord. Hold the RESET button fo at least 15 secs. then release the button and the router will boot up.
You can login using the defaults change the password and set up the wireless settings again.
I have a Belkin Wireless G Plus MIMO Router -- Model number F5D9230-4, ver. 3100. I went into my settings using the address 192.168.2.1 and accidentally clicked on something I probably shouldn't and now my...
Can you log onto the 192.168.2.1 setup page?
Is so, go to advance in the setup and set the router to it's default settings.
Afterwards, log back in and reset your SSID and Encryption key.
If you can't get to the 192.168.2.1 page, you will have to maually reset the router:
http://www.ehow.com/how_6759000_reset-wireless-plus-mimo-router.html
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Can't get on the network asks for a network password ???
You need to log in your router. you will do this by using your Internet browser, you can access the Router’s Web-Based Advanced User Interface. In your browser, type “192.168.2.1” (do not type in anything else such as “http://” or “www”). Then press the “Enter” key.
TO Log IN:
You will see the Router’s home page in your browser window. The home page is visible to any user who wants to see it. To make any changes to the Router’s settings, you have to log in. Clicking the “Login” button or clicking on any one of the links on the home page will take you to the login screen. The Router ships with no password entered. In the login screen, leave the password blank and click the “Submit” button to log in.
On the left side, under Wireless, you will see Security, click on it. change it to what ever you would like, or leave it as it is.
Belkin f5d 7230-4 How can Change Password for Homepage Login?
As you are unable to access the web interface of the device your only option is to perform a factory reset of the router using the reset switch built into it as per link below:-
http://en-us-support.belkin.com/app/answers/detail/a_id/48/kw/password%20f5d/r_id/166
How do i find out what my key code to my belkin g wireless router
Using your Internet browser, you can access the Router’s Web-Based Advanced
You should see the type of security you used (WEP or WPA) and the authentication key you used.
If you need the manual, here's a link to the download from Belkin...
http://cache-www.belkin.com/support/dl/p74880-d_f5d9230-4_manual.pdf
2answers
My belkin router is secure how do i disable it so I can use my wifi laptop
XP
Goto network places in xp and in the left panel there is a phrase "Enable UpnP Devices" Click it. let windows go through the installation
now you may have to refresh but you will see the router. click on it and log in (password may be admin no password or something like that)
goto Wireless. setup as deezired.
Vista
same as xp but no need to Enable UpnP devices.
Failsafe.....
Press the reset button on the router and goto its config page like in the prior steps. Set-up as deezired.
hope this helps sorry if does not.
1helpful
Belkin F5D8233-4 router & I pod touch wifi
What I would try is while the wifi is unsecure go on the computer and open up the browser you are using, on your router the default ip address is 192.168.2.1moz-screenshot.jpg
type the router default ip address in the browser where you would normally type a web address www.google.com
Logging into the Router
Configuring the Wireless Network Settings
The “Wireless” tab lets you make changes to the wireless network settings. From this tab you can make changes to the wireless network name or Service Set Identifier (SSID), operating channel, encryption security settings, and configure the Router to be used as an access point.
Setting up an Allow Access List
1. Select the “Allow” radio button (1) to begin setting up a list of
computers allowed to connect to the wireless network.
2. Next, in the “MAC Address” field that is blank (3), type in the
MAC address of the wireless computer you want to be able to
access the wireless network, then click “<<Add” (4).
3. Continue to do this until all of the computers you want to add
have been entered.
4. Click “Apply Changes” (5) to finish.
this will allow only the wireless device you select to access your router.
Grand Canyon Tech
Grand Canyon Tech
