Hi, I need to replace the baskets on my peavey impulse 200 speakers. The baskets currently in them are 1268MR BW... (12 inch black widow) I am wondering if I can use differant baskets, due to the fact I'm having trouble finding the 1268's.
  • 1,512 Answers
Hi dieselbob25
Whats happening to the 1268? Oh and I couldnt find that model in the standard range available to the public at the peavey sites I checked here and Peavey
They may be a special edition for the Impulse boxes. Can you tell me what is happening to the speakers? Are they burning voice coils or what. May indicate another area of concern that is making them fail.
Posted on Apr 14, 2008
I have a Peavey Impulse 200 speaker. The 12" speaker stopped working, but it and the circuit board look fine. What do I check now?
Disconnect the leads from the 12". Put a voltmeter across the speaker terminals and check for continuity. If it reads open, the speaker is dead.
May 16, 2017 | Peavey Music
Need a diagram for a Peavey 15 inch black widow
Call Peavey Customer Srervice at 877-732-8391 and they'll email it to you.
Oct 14, 2014 | Music
Replaceing subwoofer which is the hot wire
the red or white one, and polarity of the speaker is red+ black - if it is a black widow, The stamped steel peavey has the + - sign stamped into the terminal pad. you can always trace the hot wire as the one that connects to the tip of the 1/4 inch input or pin one of the speakon 4 connector. This works on any speaker.
Mar 21, 2014 | Peavey Pv 118 Pv118 Single 18" Subwoofer...
Impulse-12d low end not working? fuse issue?
No..probably blew the 12 or the amp, could be a loose wire to speaker but.....
Nov 09, 2012 | Peavey Impulse-12d 1200 Watt Powered 12"...
I have a 12" Peavey
The voice coil is probably damaged. You can get replacement basket that has the cone, basket, and voice coil for under $100 and put the old magnet on it. Reconing costs as much... you can change the basket in 5 minutes. Sometimes the voice coil partially separates from the cone or you can see it has overheated when you take the magnet off. Be careful not to get contamination in the magnet asembly. The basket is part number SP12825 RB for a 12 inch 8 ohm type..
Jul 22, 2011 | Peavey Scorpion SP1525 Loudspeaker
Looking for replacement components for my peavey speakers 2 x 15 inch 2 x tweeters 2 x crossovers 2 x horns all above for 15 inch peavey eurosys 4 product 15005760 2 x 12 inch 2 x...
Fixya doesn't do prices or delivery. We only supply information. See the link for spares suppliers including Peavey themselves.
Peavey Replacement Repair Parts, Speakers, and Accessories
Factory replacement Peavey speaker parts, diaphragms, replacement baskets. ... Peavey 1208-8 SPS BWX Factory Speaker Basket, 12" Black Widow, 8 Ohm, 00560770. Peavey SP-15825 Factory Speaker Basket, 15" Scorpion, 8 Ohm, 00015040.
Peavey - Replacement Speakers, Raw Drivers ... - Parts Express Results 1 - 16 of 323 - Welcome to the Peavey Store at Parts Express. Peavey was founded in 1965 and is now one of the best known names in professional audio. With innovative products such as their field replacement baskets, powerful amplifiers and PA speakers they have become a mainstay of musicians around the ...
Speaker Components - > Support From the Low Rider™ sub woofers, with incredible power handling capacity and impressive bass response to the steadfast Black Widow® and BWX™ speakers with replacement basket assemblies, the Peavey line of speaker components is consistent and innovative. Think it might be difficult to make up your mind what ...
peavey speaker spares Google Search
Dec 23, 2017 | Audio Players & Recorders
I have a pair of peavey impulse 200`s one of the horns just crack`s up and I have to keep it lower than the other to stop it popping.Has it gone or is it fixable cheers.
hey, just picked up a pair of used peavey impulse 200p speakers .. one of the speakers is giving out this very loud high pictched hum (obviously not working). can anyone help or advice, thanks
Mar 01, 2009 | Peavey CH1 Speaker
Peavey eurosys 500 watt 4 ohm pa speaker fault.very low volume.
Sounds like the basket has gone on the driver not sure if they are replaceable or if you will have to replace the entire driver, had the same problem on my impulse 1015, cost about £100 from a peavey dealer.
Dec 04, 2008 | Peavey PVM 22 Microphone
My Peavey Impulse 200 speaker is intermittant. Horn works fine.
There is a switched speakon plug in there (bi-amp socket).
The switch connection can go intermittent. Take the back panel of and solder links from +1 to 1+n, 1- to 1-n, 2+ to 2+n and 2- to 2-n. That often fixes it, but you lose the bi-amp capability (which hardly anyone uses)
Jul 06, 2008 | Audio Players & Recorders
Peavey KB 300 amp problems
Hi there.
You have have been unfortunate enough to experience an uncommon failure. The bass driver has failed. It is a Black Widow that can have the basket/cone/voice coil assembly replaced as a complete unit. The magnet unbolts from the basket and you bolt on a new one. Classic field service designed product. You will be able to get a new basket from a Peavey equipment stockist. Just ask for a 15' Black Widow replacement basket They cost about $180 here in Australia and you can easily change it yourself. Good Luck and happy jamming.
A FixYa rating would be great for my tech tip to you. Cheers
Mar 07, 2008 | Audio Players & Recorders
257 people viewed this question
