Question about HP Compaq Presario V2000 Notebook
My compaq presario v5000 shut down and wont restart
My computer shut down by itself and will not restart. It has happened before, when it happened i removed the battery and put it back in and it restarted. I tried that and it didn't work. I will not start with the power cord either.
My Computer just shut down and will not restart and i checked the power cord and it is getting the voltage. what could the problem be
  • ninab731 Apr 17, 2008
    no - there are no lights that turn on or nothing. nothing happens when i push the power button
  • Peter Thompson
    Peter Thompson May 11, 2010
    Does anything happen when you press the power button at all, lights etc?
  • 472 Answers
Was there any sing on the desktop saying you were running from the battery before it colapsed.
I ask because it can be two things that have done it.
The most likely is a dead motherboard. They do just fail and that's it..Just like anything electrical.
The second (and this isn't bad) is a faulty power connector on the motherboard.
Plug the power lead into it, grab the plug about 1 inch from the laptop then GENTLY move it left right up and down, and in circles while GENTLY pushing inwards at the same time.
While you are doing this, either lean around so you can see the power lights on the laptop or have someone else watch them and see if anything happens at all. Any flicker of lights etc. If so, try and find that spot, hold it, and press the power button.
This will require a bit of work to correct and best left to professionals.
Posted on Apr 17, 2008
Cq60 shut down and restarts itself
Common if backup, windows update, or defrag is scheduled to run at night. Other scheduled operations may use the restart function as well.
Feb 18, 2014 | Compaq Presario CQ60-204NR Notebook
Compaq presario v5000 won't stay
sounds like overheating , probably due to the cpu or gpu fan/heatsing loosing contact, even a little knock could have caused this
Jul 16, 2010 | Compaq Presario Notebook
UNMOUNTABLE______BOOT_____VOLUME ***Stop: 0 X
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
Computers turns on and turns off in about 5 seconds by itself
may be your reset button is pressed on....so you better unscrew your computer and then remove the plugged in botton that is lined from reset button (u can follow the layout diagrams inside the computer)... ..i think it may help you ... later you can take out the pressed reset button as well....
Apr 12, 2009 | Compaq Presario V5102NR Notebook
Hello GOD BLESS YOU all. my latop is compaq presario V5000
You can download latest drivers for your model here
Apr 09, 2009 | HP Compaq Presario V5000T Notebook
HP Compaq Presario V5000 PC - Shuts doen while plugged into AC adapter.
eather you have one or a couple of the following problems,
1. you have a bad battery
2. the power supply is defective
3. the charging circuit in the laptop is defective and the motherboard will require replacement or repaired.
Dennis
Jun 19, 2008 | HP Compaq Presario V5000Z Notebook
S-Video port on my Compac Presario V5000 Laptop
First sheck and configure display properties > settings > advance for multiple or external S-Video TV. Check device manager > display adapter > update drivers. Restart.
May 17, 2008 | HP Compaq nc6230 Notebook
Depending on your Bios Version I think later then V44 fixed a bug that would cause your computer no to start if the battery was dead with the V5000. Remove the battery and try booting from just AC power.
I have also had the same issue when my bios battery is loose or dead. The battery can be accessed from the memory area. Once you open it on the left should be memory and on the right will be the wifi card. You don't need to unplug the cables just remove the wifi card and examine the battery. The battery is held by a very very flimsy piece of platic and really easy to break. The best thing I have found is using a little piece of cardboard from a box or something and using it to keep the battery tight, just dont go shaking the laptop alot and it will hold it. It might also be possible your bios battery is dead.
From what I say I would hit power it would power for about 3 seconds the power light would flash then turn off.
Nov 01, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
111 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
