Question about Matsonic MS9158E+ Motherboard
MATSONIC MS9158 lock cpu clock
I had a 2.4ghz p4 cpu but when i install in this mother board it lock my cpu clock to 1.8ghz. i cannot tweak in bios also coz it already lock. if there anything that i can do to make it clock to 2.4ghz?
  • saber1980dz Jan 25, 2009
    i have Pentium4 2.8 GHZ but when i install it on this motherboard it gives me only 1.4 GHZ
  • patrick_1001 May 15, 2009
    please anyone help me, my matsonic ms9158e+also lock cpu clock. and i have no idea to fix it. i want to change my processor clock. thank's.
I want to know that what RAM, CPU, HD, VGAM Peripheral devices that support MATSONIC MS9158E+MOTHERBOARD?
Posted on May 04, 2010
JE VEUX TELECHARGER LS DRIVERS DE LA CARTE MERE MATSONIC
Posted on Jun 03, 2008
I want matsonic ms9158 audio driver..i m tensed...please help free driver
Seems this board uses general AC'97 Audio
Try the AC'97 Audio drivers from the Realtek website :)
Regards
1234s282
Apr 18, 2010 | Matsonic MS9158E+ Motherboard
Hello , my server mainboards fsb is stuck at 100mhz , the board can support to 133mhz , but i cant set that speed in the bios , the settings are greyed out. my cpu supports a max speed to 1500mhz but now...
It sounds like the system is set to "auto" at the moment, OR the memory speed will not support the 133mhz fsb speed, check the RAM and see what the speed rating is. Leave the CPU multiplier alone, that may well damage the cpu.
Mar 30, 2010 | Matsonic MS8137C Motherboard
Hi guys, I'm new in this forum and I really need some help. I have a p4vmm2 motherboard with Intel Celeron 2.0 Ghz CPU and I want to upgrade it with Intel Pentium 2.4 CPU motherboard. I have already tried...
Whenever you try to upgrade motherboard and CPU's with Windows XP, you're probably going to have to format your drive and re-install XP. When you originally install XP it detects the motherboard and IDE controlers for your hard drives and installs the drivers needed but it doesn't install all drivers for motherborads and IDE controlers. When you swap out motherboards and the system tries to fire it doesn't have drivers available for the new motherboard and can't complete the boot into windows. Every once in a while you get luck and the new and old motherboard can use the same drivers but this is very rare. So when upgrading motherboards plan on backing up your hard drive of all files you need to keep and being prepared to format and re-install windows.
May 15, 2009 | EliteGroup P4VMM2 V8.1 Motherboard
Intel P4 2.66GHz/512/533 is not working on MS9337C+.
#1. Does the CPU fan run if not then you may have a conductivity problem between fan and CPu. Did you use thermal paste or grease?
If fan is running follow directions below from my manual for MS9377C+ mainboard.
Go into the BIOS setup ,go to CPU setup, select proper voltage for you CPU. On Advanced setup page see if the hyperthreading function is revaeled. If so your CPU has this function. Set "Enabled " to test HT CPU function. If this doesn't work try "Disabling" the function. Good luck. I am about to attempt tp upgrade to a Prescott 3.0E which the box says this board supports. Sure hope so . Am running a 1.7 now.
umcds@sssnet.com
Apr 16, 2009 | Matsonic MS9337c Motherboard
No display on IBM motherboard
replace your ram as wwell as cmos battery
Mar 13, 2009 | Computers & Internet
Matsonic ms9158 motherboard audio problem
Here is the Audio Driver for the Matsonic MS9158E and MS9158E+ mobos.
http://www.yousendit.com/download/UmNKTXRRdWN0QTFFQlE9PQ
Jan 31, 2009 | Matsonic MS9158E+ Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
Pci simple communication controller driver
Hello fmjos:
Go to the motherboard's maker's site and download all information needed.
You must have the drivers for that mother board, and get them usually from the one who made it.
thanks,
Sep 02, 2008 | Matsonic MS9357E Motherboard
CMOS checksum bad 0085
the problem might lie in the fact that the mother board and cpu cannot be handled at the speed
or it requires the jumpers to be set by so that the cpu can be clocked properly if you got a mother board spec guide follow the guide for *********** board to set up 3.2
you might also have to set the bios to the cpu speed cause if mother board doesnt do jumpers no more the setting would be in bios
hit the delete key direct are power up this will take you to bios
its not the battery
Jun 05, 2008 | Intel Motherboard
Free download
driver audio ms9158 for xp
Mar 06, 2008 | Matsonic MS9158E+ Motherboard
Matsonic MS9158E+ Motherboard Logo
847 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
aravind shet
aravind shet
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
