I hooked up my portable dvd player to a vcr so i can watch tv on my dvd player and i can't see the picturebut i can hear the sound...
First off have you tried hooking something you know works up to the vcr and seeing if it works??
if you have and it does work then try hooking to portable up to a tv.
if it still doesnt work then its the player.
if it works on the tv then you have to assume its a copyright protection to keep you from recording dvds.
now if it doesnt work on the tv possible solution could be to make sure the cable is connected firmly, or replace it all together. you might also want to check to see if there is a switch to select the video output.
Posted on Apr 14, 2008
RCA model rtd3266
Quick and dirty:
From the back of the RCA unit make sure you are using the auxiliary input jacks to connect to the output jacks on the TV.
You will need to go into the setup menu on your TV to select an external sound system and finally you'll need to select auxiliary on the RCA unit to hear the sound from your TV.
Hope this helps,
The Tinker
Nov 30, 2013 | RCA Televison & Video
Where can i find the volume on the remote for dvp3150v/37
Your DVD/VCR player does not have a volume but your TV will control the volume for it. If you do not hear any thing is because you did not hook up the TV right.
how to hook up a DVD player to a TV - http://www.youtube.com/watch?v=fVWE4_Vyesg
May 06, 2011 | Philips DVP3150V/37 DVD Player/VCR
Trying to watch DVD played on portable Insignia player on the TV
If you hear a noise, when triying to read DVD, I am shure I´ts teh engine malfunktion.
you must get the mechanisiam or take this to a service.
I´ts very difficult for lenses to get brocken.
Jul 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
Hooking my DVD player up to my HD converter
connect as follows,,,
converter-->VCR-->TV
DVD-->VCR-->TV
watch DVD as before, when VCR is off, the converter will show up on the TV
Feb 19, 2009 | Televison & Video
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Daewoo dvd install
  1. Be sure that your VCR is a newer one with at least one "line in" set of jacks in the back. Some have one in the back and one in front.
  2. Your DVD Player should have a video/sound cable with 3 connectors on each end. Otherwise get one or 3 single cables.
  3. Connect DVD Video Out to VHS Video In (yellow).
  4. Connect DVD Left to VHS Left (white).
  5. Connect DVD Right to VHS Right (red).
  6. Turn on your DVD and VHS.
  7. Your VHS should have a tuner setting for "L1" or "L2". Select whichever shows the DVD's video on the TV.
  8. Remember to select that input channel whenever you want to watch the DVD.
  9. When watching a DVD, if you have a blank VHS in the VCR, you may record what you are watching onto the VHS, just as if you were recording from cable.
Verify these steps and you should be good to go ;)
Apr 19, 2008 | Daewoo DVDS151 DVD Player
How to record TV program while watching another
how are the cable hooked up? Is there a TV/VCR button because once you start recording, it is at VCR mode, and you need to hit the TV/VCR button to get you back on TV mode,so that you can watch TV.
Jan 03, 2008 | Polaroid PDM-1058 Portable DVD Player
How to hook up portable dvd player to watch on t.v.
You can use the VCRs video in and audio in to view the DVD player. The VCR will act as the RF modulator. You may have to select the TV/VCR button to select the input. (Sometimes line in or Below channel 2 is the L1 L2 input) The VCR has a built in RF modulator.
Dec 17, 2007 | Coby TF-DVD7107 Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
