I have a samsung hc-r4741w rear projection tv. it keeps shutting down on me. will power up after 1 min
silly girl
  • 513 Answers
SOURCE: samsung rear projection sp42w4hpx/xeu
Try plugging the power cable out for the night. If it doesn't solve it there's probably a problem with the power supply that needs professional care. Good luck
Posted on Jun 07, 2006
SOURCE: Projection TV keeps shutting down
I just took my Mitsubishi WS-65315 65" in to be repaired for the same problem and was told that it needed a new main circuit board part number 930b899005 as was told they wanted to charge me $1100.00. So I told them not to do the repair and picked up my tv and found that same part at Sears parts for only $225.00. Some of these TV repair places are theifs.
Posted on Jul 24, 2007
MikeNJ1964
  • 398 Answers
SOURCE: Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Posted on Aug 27, 2007
SOURCE: SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
got mine working better unplugged the sound and wiggled the plastic coated wire above the large fan works but freezes maybe once in a day some days never have the sound running through the receiver (surround) I shut it off and it comes back on when it does freeze figure loose connection
Posted on Jan 06, 2008
  • 2920 Answers
SOURCE: samsung rear projicton tv 42 inch aa68-50523a
youll need to have the tv converged...the red being out of line says that
Posted on Nov 05, 2008
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
I'VE HAD THIS TV FOR 4 1/2 YEARS-THINK IT'S THE BULB-REPLACE?
The HC-P4752W doesnt have a lamp. Thats a rear projection it has three picture tubes.
Oct 10, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung tv is shutting off all the time.
Do you have enough air flow to cool it?
It may be overheating....add a fan blowing into it and see if that keeps it on.If it does put a strong small computer fan in somewhere to keep it cool.
Aug 16, 2009 | Samsung HCM4215W 42" Rear Projection...
I have a 53 inch rear projection tv mine also shuts off right after i turn it on
Probably the Power supply/Deflection bd has a short and needs to be replaced.
Jul 15, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC
Replace the Power deflection board that should solve your problem. You can get a replacement board for your model at the following link.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Apr 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W power and/or convergence problems
Sounds like you soldered two of the convergence pins together by accident. If its shorted the TV will shut down.
Mar 29, 2009 | Samsung HC-P4752W 47" Rear Projection...
Having an issue with a Samsung HCP4752W rear projection hdtv...
if its on for that long its probably not a main capacitor issue a blown capacitor of that size would
have some distortion in its shape look for bulging at the top or bottom or fluid leaks at the base
a good capacitor looks like a small tin can
from the sound of it your problem is elsewhere if the picture is the picture is good then it may be a regulator or power transistor if the picture is distorted then its in your convergence circuit.
Aug 13, 2008 | Samsung HC-P4752W 47" Rear Projection...
TV KEEPS TURNING OFF ITSELF
how long does it stay powered on and do any of the lights flash if so how many times?
Dec 16, 2007 | Samsung HCN4226W 42" Rear Projection...
Sansung HC-P4752w 52 in. Rear Projection
you require a deflection board replacement the board cost around $150/
Aug 02, 2007 | Samsung HC-P4752W 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
