Question about HP Photosmart C5180 All-In-One InkJet Printer
Mac Leopard OS: Can't print from photo tray
Do you have a solution for this? there just is no place to choose the option to print from the photo tray. I have to remove my 8x11 paper and put in photo paper on main tray whenever I want to print. This printer worked fine on my PC.
  • 1 more comment
  • Anonymous Jun 17, 2008
    I experienced an issue where I could not print from the photo tray of the c5180.   I tried the export method described on the other page, but no "HP Photosmart" tab was present...
    Any assistance would be appreciated
  • karu29 Sep 01, 2008
    I can't print from photo tray and I use Windows Vista
  • rosyrotten47 Feb 25, 2009
    I'm having the same problem.   When I tried to use the Export from iPhoto on OS X 10.5, there was no "HP Photosmart" tab present.   There were other tabs on it: File Export (which has kind, quality, size, file name), web page, QuickTime and Slideshow.   When I click on Export, I get Save As and Where.   When I pulled down the where, the HP Photosmart was not available to be used.
    Please help.   I'm an avid scrapbooker and printing just one 4x6 photo onto a 8x11.5 photo paper is a waste of paper.
Here's the trick. It took me an hour to figure this puzzle out myself. DO NOT select the Print icon at the bottom of iPhoto. Do NOT select Print from the File menu. DO select EXPORT from the File menu. Select the HP Photosmart Mac tab Select HP Photosmart Print.app from the app selector. Click the Export button. HP Photosmart Print.app will load with a new print dialog box. Make all necessary selections. This is where you can select the Photo Tray as the tray for the printer to take paper from. This solved MY problem! Let us know if this helps you!
Randy
Posted on May 23, 2008
It is not necessary to use Export. I have Leopard and iPhoto 2008. Here is what work for me:
  1. Select photo you want to print
  2. Select File -- Print
  3. In the Print dialog, select the Photosmart printer, select a "Paper Size" of 4x1, and one of the presets that tells it to use Photo Paper.
  4. Click "Print" --> It won't print! Another dialog appears!
  5. A drop-down which highlights "iPhoto" is in this dialog. Click it.
  6. From this drop-down, select "Paper Type/Quality"
  7. FINALLY, you see the option for "Source," which defaults to "Main Tray"
  8. Click on "Main Tray" and change it to "Photo Tray."
  9. DON'T click "Print" yet! Instead, click on the "Presets" drop down and chose "Save As," call it "Use Photo Tray," and you won't have to do this again.
Posted on Mar 02, 2010
I didn't have the tabs he was talking about. i had to download the latest driver from HP for my Mac operating system and then they were there. turns out the driver that came with the printer was old and needed to be updated. still had to go through the export etc. but at least it works. to bad apple doesn't update their end.
Posted on Apr 12, 2009
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet Office Equipment & Supplies
Tip
How To Upgrade Mac OS X Tiger 10.4.* to Snow Leopard 10.6.*
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the <a href="http://www.amazon.com/Apple-MC581Z-A-Mac-10-6-3/dp/B002I0JKE2">10.6 Box Set</a>.<br /> <br /> <span style="font-weight: bold;">System Requirements to run Snow Leopard:</span><br /> <ul> <li>Mac computer with an Intel processor</li> <li>1GB of memory</li> <li>5GB of available disk space</li> <li>DVD drive for installation</li></ul> <span style="font-weight: bold;">Snow Leopard Installation Instructions:</span><br /> <ol> <li>Just insert the DVD in the optical drive.</li> <li>Restart your Mac while holding down the C key.</li> <li>You will be guided through the installation procedure and be prompted at one point to choose which install option you want.</li> <li>Once the Snow Leopard install is completed the Mac will restart itself.</li> <li>You will probably be asked to register with Apple upon restart.</li> <li>Enjoy Snow Leopard on your Mac!</li></ol> <b>Q: Can I upgrade directly from Mac OS X 10.4 (Tiger)?</b><br /> <br /> <i>A: Yes. Apple recommends purchasing the Mac Boxed Set for this purpose, which will also update iLife (it is unknown at the time of this writing whether older versions of iLife work with Snow Leopard) and iWork. Also note that while it has been said that the $29 upgrade will work with 10.4, it is not officially supported and may be in violation of the licensing terms.</i><br /> <br /> <b>Q: What happened to the different install options? Can't I do an Archive & Install?</b><br /> <br /> <i>A: Apple has revamped the familiar installation options for Mac OS X. You now have two choices, either a straight upgrade or a clean install. Supposedly if you choose to do a straight upgrade, what actually goes on behind the scenes is what was traditionally known as an Archive & Install.</i><br /> <br /> <b>Q: Is there anything I can do to better prepare myself for the upgrade?</b><br /> <br /> <i>A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in <a href="http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html">Onyx</a>. And finally, it would be wise to get your applications up to date using a program like <a href="http://metaquark.de/appfresh/">AppFresh</a>.</i>
on Feb 16, 2011 | Apple Mac OS X
Hi, Went to the Mac store to upgrade to Snow Leopard and was told my OS was "way too Old to upgrade to Snow Leopard!" Sorry, I'm a numbskull when it comes to these things. Figured as long as...
Apple recommends that if you wish to go from 10.4 to 10.6 then you should purchase the 10.6 Box Set.
  • Mac computer with an Intel processor
  • 1GB of memory
  • 5GB of available disk space
  • DVD drive for installation
  1. Just insert the DVD in the optical drive.
  2. Restart your Mac while holding down the C key.
  3. You will be guided through the installation procedure and be prompted at one point to choose which install option you want.
  4. Once the Snow Leopard install is completed the Mac will restart itself.
  5. You will probably be asked to register with Apple upon restart.
  6. Enjoy Snow Leopard on your Mac!
A: Yes. It is advisable to run a Verify/Repair Permissions and Verify/Repair Disk in Disk Utility. You may also want to run the maintenance tasks in Onyx. And finally, it would be wise to get your applications up to date using a program like AppFresh.
Need Epson Stylus Photo 1270 driver for Macintosh Operating System 10.4.11 - is such still available? What about same for Mac OS Leopard or Snow Leopard? Is this printer still viable for such newer...
I found the Mac OS driver on Epson's driver site.Hit the plus sign to see more information with instructions and a download link.
Not sure what you mean by "viable". Personally if it prints and does what I need it to do reliably/consistently I consider it viable. But that may just be me.
Jun 07, 2010 | Epson Stylus Photo 1270 InkJet Printer
HOW TO CONNECT MACBOOK WITH SNOW LEOPARD MAC OS X
try using the generic drivers. in Print & Fax, click on options and supplies, click on the Drivers box and type in GEN.. and choose the Generic drivers. Hope this works.
Feb 09, 2010 | Samsung SCX-4100 All-In-One Laser Printer
Mac OS 10.5 Leopard
As per someone elses post here:
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson R300 CD/DVD Tray ERROR message with Leopard any Solutions?
One of the guys on this site said read the manual over and over again, and he was right.
You must go to system preferences and choose print and fax. Set the default media to A4. Then in the Print CD program when you hit print your will see fifth line down Epson Print CD on offer. Hit the arrows on the right and choose print settings from the drop down menu and then media type and choose CD / DVD. All should then work. It does on mine.
Regards and best wishes. David
Dec 30, 2007 | Epson Stylus Photo R300 InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
1,949 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
