Question about Kenmore 44042 Front Load Washer
HELP! Good day: I have a kenmore washer model#417.44052400 about 1yr 1/2 old working fine until tonight. The Mrs. started the machine and about 10min into cycle machine beeped 3 times and Stopped and began making a gargouling sound. Turned machine off and tried to restart with same result. Removed wet clothing and then attempted to start just to drain but would not do that either. Thanks for any advise
  • Anonymous Jul 27, 2008
    Sounds exactly like my problem. Washer is about 2 1/2 yrs old same model 417.44052400. Clothes sitting in bottom of washer undrained, removed wet clothes, tried every cycle (thought drain and spin would work when clothes were removed -- wrong). Machine buzzes, clicks, buzzes some more ... eventually shuts off. Try to start a new cycle .... same old thing happens. Help -- I have company and need the washer to work ASAP.
    HELPME
  • federnuk Sep 06, 2009
    Thanks for the advice I was lucky in that all that was wrong was the main drain was clogged with some socks and change and dirty mold.. Quick fix- removed rubber hose and items cleaned machine with vinager.
  • 33 Answers
I have the same onebut fridgeair but mine would only wash and nothing else and it turned out to be the motor was weak
Posted on Jul 13, 2008
I have a kenmore front load washing machine 44052 that is 2 years old. It has stopped working. Call repairman he said 800 to fix. Need a new tub. What I found out after taking apart myself is the inside is loaded with mold, Bearings are faulty and the spyder rack in back is made of aluminum that will corrode. I am trying to start a recall on this machine for faulty bearings, spyder rack and mold.
Posted on Sep 17, 2008
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
I have a Kenmore washer model #110.20022011. The other day it did not spin out all the way, now it will not start at all. The fill light and lid lock light comes on, but it does not start. Water and...
A friend of mine bought a Kenmore washer model 110.20022013 a year ago. Now washer stopped in the middle of washing and a clicking sound starts, and not washing or rinse or draining
Aug 22, 2011 | Kenmore Washing Machines
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Whirlpool lsr8233jqo - will not spin
if you hear the motor running then it is most likely the direct drive coupling between the motor and transmission. part #285753 you can see it from under the machine.477922b.jpg f3941f5.jpg
Jul 16, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Plese help
Its hard to diagnose these motor problems...takes a volt-ohm meter with a capacitor checker.... and a lot of knowledge if youre up to it, ill try to help.
Jan 24, 2008 | Kenmore 22422 Top Load Washer
Washer problems
How old is the washer? Some washers you can pop the top on if so check your power cord as it enters the washer. There may be a loose or burnt wire at the terminal block. Some washers won't start if the lid switch isn't making. Check that also.
Dec 11, 2007 | Kenmore 98702 Stacked Washer/Dryer
Not starting 1 yr old kenmore elite smartheat quietpak9 HE4
SEE VIDEO
http://www.youtube.com/watch?v=tq3k22cqjR8
Control panel moisture 9/10 times.... or check the fuse under the lower front panel ($12 sears)
Nov 28, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore 44042 Front Load Washer Logo
444 people viewed this question
Sal De
fordexpert
Robert Rankin
