Question about Microsoft Zune JS8-00001 Digital Media Player
My zune has a power problem
And you said black button
butttt...mine is a 4gig red zune...and has no red button
Pleas,help me!
my zune it has power on but no boot hardish.it tune on then shut down.can you help me pleas
Posted on Apr 30, 2008
  • vanluc Apr 30, 2008
    i buy a zune 30g .it no power on .pleas help me!
My zune 120gb stuck on contact support page and can't pay 18-30 u.s dollars to get help from support, should i throw mines away i'm fed up with problems comming up where i have to pay MORE money to fix.
no, dont just do the following On your zune make sure the hold button isn't on
At the same time hold down the back button and upwards on the directional pad until the screen goes black
then use your left hand and press the back button while using your right index finger to press the middle of the zune pad use your middle finger (on your right hand) to press play pause button. All of these need to be held at the same time. You should get a please wait message. follow the instructions on screen.
Jun 06, 2010 | Microsoft Zune JS8-00001 Digital Media...
I cant seem to turn off my zune completely, only pauses the unit, the screen goes black after holding the pause button, it appears to be off, then i go to use it hours later and the battery life has...
The Zune never really turns off completely. To turn it off, hold the back button and up on the Zune pad. As soon as the screen turns black, let it go, and turn on Hold.
This will turn it off completely.
Mar 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
My zune went black
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Feb 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 80 GB - Won't Charge
i lost my drivers microsoft lifecam vx-1000
Feb 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Stuck on startup screen.
pull the case apart and pull the battery out for about thirty seconds. put it back in and back together and it should work.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
MY ZUNE WONT TURN ON OR CHARGE AT ALL
my zune just went black screen and will not recarge or anything else.
Nov 17, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Unresponsive (and dead battery) zune o' saddness
Power sources that are supported loadTOCNode(2, 'moreinformation'); To charge the battery in your Zune device, you must connect the Zune device to one of the following supported power sources:
  • A computer’s USB port that you can connect to by using a Zune Sync Cable.
  • A Zune AC Adapter that you can connect to by using a Zune Sync Cable. Note The Zune AC Adapter is sold separately.
  • A Zune Car Charger or a Zune FM Transmitter/Charger. Note These items are sold separately.
  • An Xbox 360 console's USB port that you can connect to by using a Zune Sync Cable.
  • A “Designed for Zune” mobile battery pack
http://support.microsoft.com/kb/927348
Nov 09, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune sucks
Try this....
Hope this helps!
Oct 23, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
my 30gig was doing same thing i opened it up and one of cables just slipped out of port very simple to fix open you zune where the charger goes in there is a black cover remove this carefully then remove the 2 very small screws next use a very thin flat surface be very careful and you can see the edge where it seals just put you thin applient into the side and gently pull it up go all the way around once at top be gentle dont use the knife or whatever you used just slide it appart the back will come off then just reconnect cables good luck
Sep 30, 2008 | Altec Lansing M604 Computer Speakers
Microsoft Zune JS8-00001 Digital Media Player Logo
35 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
