Question about Car Audio & Video
I have a cd stuck in my kenwood kvt 719 head unit and the touch screen controls for the dvd are not appearing.
  • Anonymous Jan 09, 2009
    i have the same problem. The reset didnt work.
  • 23 Answers
Have you tried hitting the "Reset" button on the head unit?
The procedure is on page 7 of the owner's manual under the heading "How to reset your unit"
Here's the URL for the Owner's Manual:
http://inform3.kenwoodusa.com/manuals/KVT-719DVD.pdf
Per the owner's manual, you're supposed to call Kenwood technical support if the display doesn't correctly reset or come back on and/or if the disc won't eject.
Posted on Apr 14, 2008
How do i wire up m Kenwood KVT-696 so that i can play DVD's, it shows a blue screen saying 'parking off' do i connect my AV in or AV out cords coming from the head unit?
For safety, the KVT-696, like other 'head units,' is design so that, properly installed, it will only work while the vehicle is in Park, with the parking brake ON. Makes sense if you think about it. Hey?
Jul 03, 2014 | Kenwood Kvt-696
Kenwood kvt-815 dvd touch screen not working
did you ever find a solution for this problem, I am currently experiencing the same thing
Jul 18, 2009 | Kenwood Excelon KVT815DVD Car DVD Player
Kenwood kvt m700 touch screen problems
You don't need a code, it's unlocked by the remote that came with the unit (small purple one)
Jun 26, 2009 | Kenwood KVT-M700 Car DVD Player
Touch screen doesn't work. It is a kenwood KVT512 DVD/CD player with a 7" touch screen. at first, I couldnt get any of the buttons to work, not even the power button to turn the unit off, so i pushed the...
The password can be entered by setting the arrow buttons, if u know the password, or get kenwood to give their default password and check that the touch screen is not getting grounded, 'cos that's when it goes apparently, dead...sodeep
Jun 23, 2009 | Kenwood KVT-512 Car DVD Player
Hideaway brain unit on my kenwood KVT-617 doesn't work
My KVT-617 display unit was stolen out of my dash, but they neglected to snag the items under the rear seat: the "brain" hideaway unit, the HD radio receiver, the 10 disc CD changer, the navigation unit, and the powered subwoofer.
Everything was replaced via the insurance except the sub because the new system was not compatible with the old components. Make me an offer on the items you want!
timsterp99999@att.net
May 29, 2009 | Kenwood KVT-617DVD Car DVD Player
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
Kenwood kvt-719 brake bypass code needed
I've never seen a code that allows it, but you can do it in the wiring harness. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 15, 2008 | Phase Linear UDV9010 Car DVD Player
Wiring diagram kenwood kvt 810
go to kenwoods websight and the have downloadable install manuals
Feb 02, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
Kenwood KVT-617DVD
hi kenwood go's off when i put it on to dvd
Jan 16, 2008 | Kenwood KVT-617DVD Car DVD Player
Car Audio & Video Logo
170 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
