Question about Eureka 4467AV Upright Vacuum
Eureka upright vac. no suction
Eureka upright vac.not getting any suction. Hose are clear.
  • Anonymous Mar 16, 2014
    Eureka smart vac the boss 4870 no suction
    Sergeant:
  • 209 Answers
Dear wymanwong
Righteo, your problem is not exactly all that straight forward as i dont have a great deal of information to go on with regards to this type of issue and this make/ model of vendored appliance, so I will begin by explaining how the typical vacumn cleaner functions (in relation to your issue) and what can cause a fault of this kind.
The vacumn cleaner overall (unless is a liquid cleaner as well as a conventional dry suction unit) has the function of providing suction into either a chamber or bag which is either filtered or emptied, and the effects of loosing suction usually are effected by faults within filters, or directly through the motor that is normally powered through 240V~ (AC) within the UK or
115~ (AC) USA. Suction can also be lost through blocked exhaust outlets through the vacumn unit and also through any perforations or tears to a bag/ container that is used in order to maintain constant suction and storage of particles/ vacumned waste.
Now to investigate the fault you have in regards to loss of suction within your unit.
Firstly You should query the suction motor and the copper windings as these are both electronic and mechanical components that can be affected not only by general wear and tear, but also by various ingressions (such as water and liquids). Also heat can play a major role here, as motors can spin up to a large amount of revolutions per minute (RPM) and this will cause heat build up, add this to the fact that the windings inside most electric motors are made of copper, and you can quite easily discover that the motor will "burn out" as copper will break down at somewhat lower temperatures than other electronic components (this is also more likely as the casing of a DC/ AC motor is contained within a steel structure which is a good store/ conductor of heat).
The other factor that should be considered with vacummn failures is also associated with exhaust impedances. In otherwords, if outlets and filter channels are blocked, then overloads through the motor wiill be likely and the entire system may cease altogether.
In addition to this, investigations of the power supply and any power transformers within the unit should also be queried, along with any rectifiers (used for converting an AC signal to a DC signal for use with DC motors if necessary), as faults with these can occour even over short periods of time.
If queriying these components have returned no results to the fault, then there is always the option of attaing the service sheets for your appliance from the manufacturer/ vendor of your appliance. The best thing to do in this case is either to go to http://www.google.com or to the website that is listed for your manufacturer/ vendor. Now if google if your option, then there are a few keywords which will assist in your search for your service sheets and they are to simply either type your appliance name followed by the words "service sheet" or "repair manual" In addition to this, you can always contact the manufacturer/ vendor of your appliance directly by telephone and delegate with them in order to request user manuals and servicing guidelines, and given the fact that you have a small appliance, if you mention that there is a possibility you would order any spare parts through them, then i really cannot see a reason why they would decline offering you the servicing guidelines/ manuals at a low cost.
Now there are other things here that can be investigated, but in order for me to dfo this i will need full details of your appliance model number and maufacture code, along with full details of the fault, as accurate as possible. Also photographs of either the machine or any/ all of the internal components will greatly help as direct visuals will aide not only in the identification of your make/ vendor model, but also may give a visual clue of what could be defective within your appliance (for example scortch marks on the wiring that supplies your vacumn motor etc) But any pictures supplied will need to be of a high resolution and quality.
Well I do hope that this brief explanation will provide enough information for a fixya or even a total unit overhaul in the most cost effective manner, in addition to this i do hope that i will hear from you in the somewhat near future as so i can find out more about your fault and indeed if you have managed to resolve it elsewhere (and even how this was done).
I am here most days and nights and any contact to and from me will ensure that I endeavour to resolve your technical issue in the most appropriate way for you.
In the meantime, i do hope you take care, and look forward to hearing from you soon
yours sincerely
Oz
Here on demand for all your technical needs
Posted on Apr 14, 2008
Why doesn't suction work on eureka
The hoses may be clear but debris could be clogging the point where it is discharged into the bag or container. There also could be a debris clog at the intake.
Sep 03, 2014 | Eureka Vacuums
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
Aug 16, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka vaccuum blowing out and not sucking in
Hi There,
I am going to assume you are talking about a Eureka upright vacuum.
The cause for this is generally either
A) Broken Belt - Which you can easily fix by changing belt
or
B) Blockage in the hose somewhere - Basically test the suction with the machine turned on with you attachment hose and see if you have suction. If you do check the belt and make sure you clear out any muck left around the roller.
If you need Eureka vacuum belts go to VacuumSpot.com.au
May 13, 2012 | Vacuums
Eureka Model Whirlwind litespeed. The rotart brush does not turn or rotate. Should it turn or rotate in order to give better suction?
Hello fnintel, yes, if you are using the upright vacuum it should spin, ( the belt likely slipped off, or the brush is clogged with hair and the likes.)
However, if you are using the hose on the vacuum like a shop vac, some models bypass the rotary brush.
Jan 09, 2011 | Eureka Whirlwind Litespeed 5840 Bagless...
Eureka Optima vacuum has suction at the hose but not at the floor. I took out the filter and it still isn't suctioning so I don't think it is the filter.
it sounds like you have a plug. check where the hose goes into the back of vac. it should have a clip remove this and see if there is a plug there
May 18, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Hose has no suction
Most uprights need to be in the up-right locked position to enable the hose pickup.
Jul 25, 2008 | Eureka 4874 Bagged Upright Vacuum
Hose suction Eureka theboss smartvac
There has to be a clog in the hose, Unhook the hose and drop like a big marble in it to see if it comes out the other end.
May 10, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka Enviro Vac Model 4470 Not Sucking
First, check to see if there is suction without the hose on the base. If not, and there is no blockage, the problem is likely a damaged impeller, the small fan that makes the suction. That will have to be replaced.
May 21, 2007 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 4467AV Upright Vacuum Logo
225 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
