Question about Maytag Atlantis MDE7400AY Electric Dryer
Smells hot what do I need to check? - Maytag Atlantis MDE7400AY Electric Dryer
  • 525 Answers
Check your vent to the outside to make sure it is clear of obstructions, lint build up, water retention due to a sagging vent, etc.
Posted on Jun 02, 2008
I have a 2002 Mitsubishi Diamante the coolant fan will not come on. The gage says it isn't hot but it smells hot. What could be the problem ?
check fuses and relays -engines smells hot [all engines put out heat and smell hot ]could be nothing the engine could be running correctly or test the temperature sensor ,fan motors and fan circuit --if smells hot because of leak look for leak have coolant system pressure tested
Oct 15, 2016 | Mitsubishi Cars & Trucks
New dryer smells hot
It is not unusual for new appliances, espicially high heat ones like a dryer to smell hot. Also if this is your first gas appliance it might smell different than your old dryer if it was electric. Keep an eye on it when using it to see if you see any smoke. Also check your venting to make sure it is all clear with no blockage.
Jan 10, 2015 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My dyson DC50 smells when hoovering
many things can make it smell bad wash filter top and lower in hot soapy water and rise well and dry well in sun
wash bin and all it's parts in hot soapy water and dry well
clean brush roll and check for any bad smells in head
could be from motor over heating or near to failing if above does not get rid of smell i would say it's the motor
May 31, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Rad smells hot
Sounds like they checked your coolant and left the cap loose or spilled oil on your valve cover and it's dripping down on your exhaust manifold.
May 09, 2014 | 2004 Subaru Forester
SMELLS HOT
Do you have a leak, check under the car to see if any coolant is on the ground. Smells hot is kinda vague. Does the gauage indicate hot? If not you likely have a leak.
Sep 27, 2012 | 2003 Kia Sorento
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
99 pontiac grand prix smells hot after driving 30 minutes
If the temperature gauge looks good (under 3/4) its all good. If not, then there is a problem. If it smells hot inside, like moist and humid you will need to replace the ac filter, that can be located under the hood, close to the water resevoir, you will have to pull the ruber type gasket that is on the edge of the hood/wiper cover.
Oct 02, 2009 | 1999 Pontiac Grand Prix
Runs hot and smells
YOUR BELT IS PROBABLY BURNING UP
NEED TO REMOVE OUSTIDE HOUSING AND REPLACE
BEFORE TACKLING, HAVE SOMEONE TILT MACHINE BACK AND CHECK THAT NOTHING IS INTERFERING WITH TENSIONER PULLY
May 26, 2009 | Dryers
My Ford Ka smells like its overheating
check your water in the radiator bottle, normally that kind of smell is caused by low water level
Mar 29, 2009 | 2005 Ford Focus
Maytag Atlantis MDE7400AY Electric Dryer Logo
77 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
