Question about Canon imageCLASS D860 All-In-One Laser Printer
System error E000
Alarm light on, system error reading E000, Canon D860 Canon D860 error E000, unplugged for 10 minutes per manual but that didn't clear the error
  • 5 more comments
  • Angel773 Apr 22, 2008
    I was making copies and all of the sudden sytem error E000 appeared. I removed the toner cartridge and checked to see if there was any paper stuck. I took out the drawer where paper was fed. I removed the plug for about 10 minutes and same system error appears. Please advise.
    I would appreciate any help I can get.
    Thank You,
  • Anonymous May 20, 2008
    My machine has the problem of System Error, making copies and was suddenly lit light as the disconnect and wait 10 minutes and even said System error.
    I can help?
    thanks
  • Anonymous Jun 18, 2008
    error e000
  • Anonymous Oct 07, 2008
    I have the same problem. System Error E000 with alarm light blinking. No paper jam present. Restarted copier. Unplugged overnight. Still not fixed.
  • Anonymous Dec 07, 2008
    SCUSATA IN ITALIANO NNO CE?
  • orcentersa Feb 18, 2009
    I have the same error code E000
    What's the fix?
  • ANDY Jul 31, 2012
    Clear error in service mode, switch off and on, If fault continues the fixing unit is faulty
  • 4 Answers
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Posted on Apr 24, 2009
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Please let me know if you need any further help
Apr 06, 2008 | Canon imageCLASS D860 All-In-One Laser...
System error E000
  • Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer"
  • Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
  • Then press "Set" again, and the display will ask you "Yes" or "No"
  • Press the "Left" arrow for "Yes", then press "Set".
  • Now, unplug the power cord and wait 5 seconds and plug back in
That should clear the error. If it doesn't, get a new fuser.
Feb 29, 2008 | Canon imageCLASS D860 All-In-One Laser...
Error Msg E000
E000 is a fixing unit failure...either the thermistor or fixing lamp failed. Not sure about individual part replacement, most likely needs entire unit replaced....then reset the code.
Aug 03, 2009 | Canon Office Equipment & Supplies
System error E000
Press the "additional Function" key
Press the # key
Press F3 key until "Printer" shows up.
Press "OK" key
Press F3 key until "Printer Reset shows up
Press "OK" key
Press the * (star) key
Turn printer OFF then back ON
Jul 07, 2008 | Canon imageCLASS 2300 All-In-One Laser...
System error E000
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser.
Feb 14, 2008 | Canon imageCLASS D860 All-In-One Laser...
System error E000
check the settings for the alarm and also the software.
Jun 10, 2008 | Canon imageCLASS D860 All-In-One Laser...
System error E000
E000 is a high temp. error. My first advice would be to atempt to clear it in service mode:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 Printer and press OK
  3. Go to #4 Printer Reset and press OK
  4. Yes = ( * )
  5. Power cycle unit.
If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistors. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area. However, on this one, I would recomend replacing Fix Assy. as a whole if you can, FG6-8326-000 (for s/n starting with MQT/MQV/MRV/MRW) or FG6-8325-000 (for all other s/n). Don't see p/n for Thermistors. Also, heard of alot of other board and p/s issues with this model that can cause E001-E004 errors. See if you can clear it first. Good luck. Let me know how you make out.
May 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
System error E000
Press #
Press Set
Press Set
Press <
Jan 14, 2008 | Canon ImageClass D880 Copier
System error E000
That's was a miraculous!!!!! My canon Image Class D860 is brand new now after following the steps.
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
This just worked for me on a D860
Thanks
Evenel
May 07, 2007 | Canon imageCLASS D860 All-In-One Laser...
Canon imageCLASS D860 All-In-One Laser Printer Logo
1,868 people viewed this question
old marine
old marine
