Question about Casio EXILIM EX-Z1000 Digital Camera
Camera won't turn on
Camera is 1.5 yrs old, 30 took pictures fine last weekend. Later that day it wouldn't turn on. After charging it on the docking station from red light to green light, it still won't turn on. I've even charged the battery on the separate wall charger and it also indicates it is fully charged but it will not turn on. When I take the battery out and re-insert it the greed light in the camera blinks once, but when I push the on/off switch nothing happens. This is the original battery and so I have ordered a new one and am awaiting its arrival; however, upon some preliminary Google searching, I find others have similar problems. I am writing for advice/ suggestions beyond "try replacing the battery" because I feel the problem runs deeper than that.
Thanks y'all.
  • Anonymous Apr 27, 2008
    i cant get my camera to turn on at all either. only sign of life i get is if it is on the charger and i hold the play button on top, but once i take it off of the charger it goes off... please help
  • dinkytoys Jun 14, 2008
    Same problem here, it seems. I press the on-button, and the camera turns on for a couple of seconds, after which it switches itself off. Camera is about two years old. One day it worked fine, the next day, it does not.
I have the same problem with this camera! ahh help!
Posted on Jun 08, 2008
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
NO PICTURES
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00614986&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=437165Solution two: Use the right battery What AA battery should I use for best performance? The following table summarizes how AA batteries perform in different types of use. Type of Use Alkaline NiCd Ni-MH Oxyride Photo Lithium Most economical when taking more than 30 pictures per month Poor Good Good Poor Fair Most economical when taking less than 30 pictures per month Fair Fair Fair Fair Good Heavy use of flash, frequent pictures Poor Good Good Fair Good Heavy use of video Poor Good Good Fair Good Heavy use of Live View Poor Good Good Fair Good Overall battery life Poor Fair Fair Fair Good Low temperature/winter use Poor Good Fair Poor Good Infrequent use (without dock) Fair Fair Fair Fair Good Infrequent use (with dock) Fair Good Good Fair Good Recharge batteries No Yes Yes No No Solution three: Make sure that your batteries are completely charged Follow the steps below for your battery type: Ni-MH rechargeable batteries Ni-MH batteries lose charge, or self-discharge, at a rate of one to two percent per day, whether they are installed in the camera or not. This means that if a battery is fully charged, after several weeks, the battery will be low or dead even if it was not installed in the camera or if it was installed in the camera but no pictures were taken. Ni-MH batteries are best for those who use the camera frequently and recharge often. The amount of charge that Ni-MH batteries can hold gradually decreases because of usage, aging, and lack of maintenance. To maintain your batteries at maximum capacity, "condition" them when they are new or have not been used for over a month. Follow these steps to maintain (condition) your batteries:
  1. Completely discharge the batteries by using the camera normally until it will not operate.
  2. Recharge the batteries.
  3. Do this three or four times.
NiCd rechargeable batteries Nickel-cadmium (NiCd) batteries lose charge or self-discharge at a rate of one percent per day. Store NiCd batteries in a cold place such as the refrigerator or freezer to minimize the loss. To store in a cold place, place the batteries in a tightly sealed container to keep the moisture out. Before using them, warm the batteries to room temperature. The amount of charge that Ni-Cd batteries can hold gradually decreases because of usage, aging, and lack of maintenance. To maintain your batteries at maximum capacity, "condition" them when they are new or have not been used for over a month. Follow these steps to maintain (condition) your batteries:
Alkaline, Photo Lithium, and Oxyride non-rechargeable batteries Make sure that the batteries are new and have not been used for anything else. . Solution seven: Try a new set of batteries If you have tried all the solutions described above but your batteries still do not last very long, try a new set of batteries. If the old batteries are damaged, a fresh set of batteries will solve the problem. Batteries can be damaged in the following ways:
  • NiCd and Ni-MH batteries can be damaged by over-charging. After a battery has been recharged, do not try to add additional charge to the battery by sending it through another recharge cycle before using it.
  • Batteries can be damaged by dropping or sudden impacts. Even if there is no apparent external damage, the rechargeable battery could later develop an internal short or leak while in the camera and cause damage.
  • If batteries have become wet, they may short out and will not work properly.
Jul 17, 2010 | HP Photosmart M417 Digital Camera
Digital rebel battery drain with flash only
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Nov 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Blurry pictures, and zoom not working
yeah the same thing happened to my camera last month and I just went to the repair place yesterday. Apprently Casio products arent that sturdy so if they get hit the lens can become misalligned and you can't fix it yourself. A new lens is more than the camera itself so if you have to get a new camera I wouldnt suggest another casio one. Good luck.
Aug 13, 2007 | Casio Exilim EX-S600 Digital Camera
Casio digital camera ex-s600 won't turn on
*** SOLUTION *** Mine had the same problem. My camera works now. What did the trick for me was removing the Flash Card. It appears card went bad and the camera would never power on because of this. I just removed the card and the camera powered on. I tested the card on my printer and it wont let me read or reformat. Hope this helps. -HenryVerde
Aug 08, 2007 | Casio Exilim EX-S600 Digital Camera
Kodak DX6440 won't power up using batteries
There's a chance that the drop is irrelevant to your problem. You could try using a small eraser to clean the battery contacts down in the chamber (make sure to dump out any eraser particles) and try a new CRV-3 battery, which because of it's slightly longer body produces a little more pressure on the contacts. If that doesn't work to improve things then your cam might need a repair, your call there. Good luck
May 02, 2006 | Kodak EasyShare DX6440 Digital Camera
When the EasyShare digital camera is not in use, and the battery is fully charged, can I leave the camera (turned off) in the dock?
The EasyShare camera dock automatically stops charging the batteries after it registers a full charge, so it is fine to leave the EasyShare digital camera on the EasyShare camera dock for short periods. However, leaving the camera on the dock for longer periods (days or weeks) is not recommended because this can cause problems with your camera and the batteries.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Casio EXILIM EX-Z1000 Digital Camera Logo
63 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
