Question about Ulead Videostudio 8 for PC
EasyCap installation problem -
I installed the drivers for EasyCap, but when I go to install the video studio, I get a message that says "CRC error- The file doesn't match the file in the setup's .cab file. The medium from which you're running the setup may be corrupted. Contact your software vendor." Then the next message is "DLL function call crashed"
Is there any solution to this? Is the install CD just corrupted? Help!
  • lilredss02 May 13, 2008
    Hi I recently purchases the easy cap off ebay but when i recieved it, the installation cd was cracked and now i cannot load it on my computer. Is there anyone that has the yellow installation cd out there please email me a copy of the software to jmramer01@iccms.edu
    thank you so much,
    Jason Ramer
  • 3 Answers
SOURCE: easycap002 on windows vista
From what I have experienced, EasyCap 4channel USB DVR (model: easycap002) does NOT do simultaneous 4-channel updates, rather successively updating each of the 4 channels one after the other, each taking, at the fastest update speed, about 1/2 seconds per activate channel. Also, I've been unable to make the included EasyViewer software do audio recording. Furthermore, in video record mode, EasyViewer ONLY captures ONE channel's video, not all 4 together.
I had better recording results, albeit only 1 channel with sound, using the software on the same CD named D:\drivers\files\stkatvap.exe although it requires some menu configurations to get it working --I'll cover this at the end of this post.
You are FAR better off finding some third-party recording software that MAY be compatible with this 4-channel easycap002... I don't know if there even are any compatible ones, however, but I know this EasyViewer crap they provided sucks.
I have had a LOT of problems with easycap002 4 channel USB dvr as well (hardware name is Syntek ST1160). I have it working periodically. Because I had the drivers already installed (as I am sure you do) I plugged in the easycap and clicked start > administrative tools > computer management > system tools > device manager .. right pane: +imaging devices .. right click on Syntek STK1160 and choose Uninstall and [x]delete the driver for this software. Unplug the easycap USB cable. Reboot. Login and insert the install CD that came with easycap run the autorun. Whith Easycap unplugged, choose Install Driver. If it asks you to "completely remove" then answer "yes" and after it is done eject and reinsert the CD again and choose "install driver" yet again to do the actual install this time. Click OK to the prompts to get the driver re-installed. Although you're on Vista, it installs as XP. After install is complete, plug in the easycap002 4-channel USB cable. Wait about 10 seconds to be safe then click start > administrative tools > computer management > system tools > device manager .. right pane: +imaging devices .. you should again see the "Syntek STK1160" there not having a yellow symbol over it. For the heck of it, reboot again then install the 4-port imaging software if you have not already. Be sure to plug in at least one device/camera so you have something to test. NOTE: I could NOT use the icon it put on my desktop, I had to literally go to the install location of the softwrae and run NOT easyviewer.exe at the root of the CD, but go into directory SYS\XP\ and use EasyViewer.exe there!!!! It will come up saying there is "no signal" initially but you'll see at bottom center it saying "search[ing]" so wait until that search is done so it can identify the cameras plugged in. Normally it takes up to 10 seconds for it to realize a source is plugged into one of the 4 video ports which makes debugging this thing take FOREVER. Also, initially try to use short length higher quality RCA cables so you don't risk signal loss which will complicate your troubleshooting. If you unplug a video source or the source shuts off, EasyViewer will say "video loss" and you are best to just kill and restart the EasyViewer software again - I've rarely had it re-recognize a reconnected source after plugging it back in without needing to restart the software.
If you're using less than all 4 input sources, disable the unused ones as it'll make display updates much faster by option Channel > channel control > [x]automatic ..uncheck what you are not using.. make Fast Turning:[x]enable .. and Turning Time: 1 Sec (the fastest each display will update) [ok]. Trust me, you'll want to do this to have faster display updates which are slowwww to begin with.
If video is in black and white it COULD be you have a low quality RCA cable, but likely is your needing to change setting Property> tab Video Decoder : video standard: ntsc_m (ntsc_m_j is black and white.) .. also Tab IMAGE : Video Sources: [x]Ntsc_m [x]Composite ...if on S-Video you won't see anything on this easycap002 4-channel model as it does not have an s-video input.
* What is annoying is that not all 4 channels are continually displaying. They CYCLE in updates, channel 1 taking 1/2 second, ch2 thereafter takes a 1/2 second, ch3 thereafter 1/2 sec, etc. This is why earlier I said to DISABLE any channels you are not using, saiving you 1/2 second of update time per disabled channel. I was hoping for smooth simultaneous updating. The only way to get smooth video is to watch ONLY 1 channel - do this by clicking at upper right of window Auto Turning Focus:OFF and click on the channel you want to watch in somewhat smooth mode (~15 frames per second (15fps)). Click Auto Turning Focus:ON when you want each to update, taking ~1/2 second each.
This slow 1/2 per channel update is rediculous.. It defeats the purpose of security video in my view, a person can just run across the channel's view and never be caught during the updates of the other channels which can take 1.5 to 2 seconds.
THE WORST PART: I've found NO WAY to record ALL 4 channel's video at once! I can only record a selected frame to video .avi !! Unbelievable. You CAN take a manual "snap shot" of all 4 frames however, but how useless is that. Clicking "RECORDER" locks up the LIVE display of all but the channel you're recording. Clicking "recorder" again to stop recording locks up the display for a couple of seconds but then resumes the alternating channel display updates.
Be warned: viewing the created .AVI is only reliable in Microsoft MediaPlayer, it only sometimes works in Apples' QuickTime viewer.
I've not been able to get sound to record in EasyViewer either.
I was able to get sound to work under another software provided on the CD. As mentioned at the start of this post, I had better recording results, albeit only 1 channel with sound, using the software on the same CD named D:\drivers\files\stkatvap.exe although it requires some menu configurations to get it working.
After running s5katvap.exe, plug your vid source into channel 2 of the EasyCap002 device, yes, the cord labled 2 and put the source audio into the white cord. Choose DEVICES > [x]Micorphone (usb audio interface ... OPTIONS>[x]Preview [x]Audio Preview ...
To make the video display smoother, you need to choose the video output format CAPTURE > CYCLE MULTIPLE VIDEO FORMATS > For the UnitedStates [x]320x240 UYVY or [x]640x480 UYVY
Note: Audio lags behind the video by about 1/2 second in the preview mode, but it is only slightly off when you playback the finished actual recorded .avi video file.
Now set where you want the capture to go to: FILE > SET CAPTURE FILE > ...
Now start recording with CAPTURE > START CAPTURE
Don't know if this helps much.
I'd appreciate any feedback anyone can give on better controlling software for this 4-port/channel DVR.
johnjneumann@hotmail.com
Posted on Jan 05, 2008
SOURCE: EasyCap Video Capture
Hi
I had the same problem. No picture and no sound.
Here is what I did to solve it.
1. I Un-installed the software and restarted the computer.
2. Placed the installation CD (that came with the product) back in the CD drive.
3. Click on "Install Driver" (this only installs the USB 2 drivers so that the computer can see the device)
Make sure you do not attach the Easycap Device before you have installed the USB Driver (as above).
4. Once USB Driver has been installed then plug in the Easycap USB Device, windows should then detect the new device, to make sure:-
5. Right Click "My Computer" "Properties" "Hardware" "Device Manager" check "Imaging Device" (which is where my STK1150 Driver was installed) and make sure it has no yellow exclamation mark next to it.
6. Go back to CD and "install the Uplead Software", you then have to Restart the computer.
Once all installed you can then connect your external device VHS Player/Camcorder etc to the Easycap device, using the Red/Yellow/White leads.
I like many before me, tried and I tried to get the image to play on the software "Capture" screen but all to no avail, I was pulling my hair out, I wasted two days on it, I finally decided that this product was a total load of rubbish and I had wasted my money and it had to go.
Then a major break through, some smarty pants made the comment about INPUTS & OUTPUTS, my prayers along with many others could have been answered ??....
I had actually plugged the Red/Yellow/White leads into the INPUT terminals of the external VHS Player, when they should be plugged into the OUTPUT terminals of the external VHS Player/Camcorder.
On a Camcorder the RED/Yellow/White terminals are usually Output terminals but on a VHS Player they are usually always Input only !!....
I tried running my Camcorder through the software and Hey Presto that worked a treat.
So in order to get my VHS to play through the software I ended up having to buy a Scart OUT (very important "OUT") Red/Yellow/White adapter (see link for product image)
http://www.maplin.co.uk/Search.aspx?criteria=scart%20out&source=15&SD=Y
Once all connected I pressed play on the VHS Player and I have to say that nearly fell off my chair "IT WORKED - IT WORKED - IT WORKED"
Posted on Feb 16, 2008
cgpatel1948
  • 258 Answers
SOURCE: easycap install driver
Your accounts seems to me as user and not Administrator
Posted on Jul 30, 2008
SOURCE: easycap video adapter driver will not install on PC from the CD
Goto youtube.com. and search:How to get EasyCap Drivers or http://www.megaupload.com/?d=W64LW1DJ and type in the 3 LETTERS.Wait for the free download on the right side.After I installed the Syntek STK 1160 drivers I still could not capture.THIS STEPS SOLVED IT: 1.OPEN THE ULEAD VIDEO STUDEO PROGRAM 2.CONNECT THE EASYCAP USB DEVICE 3.ON TOP CLICK CAPTURE 4.IN THE MIDDLE CLICK CAPTURE VIDEO.5.UNDER THE WORDS:CAPTURE FOLDER, CLICK ON OPTIONS (THE LITTLE ROUND GEAR OBJECT) 6.CLICK VIDEO AND AUDIO CAPTURE PROPERTY SETTINGS 7. CLICK SOURCE 8. MAKE SHURE TV SYSTEM IS THE ONE IN YOUR COUNTRY 9.CLICK OK.10.A BLUE SCREEN APPEARED AND WHEN I PUSHED THE PLAY BUTTON ON THE DV CAMCORDER I COULD CAPTURE THE VIDEOIMAGE ON THE LEFT SIDE.
WHEN I INSTALLED THE ULEAD PROGRAM I DID SELECT THE TV SYSTEM IN MY COUNTRY(PAL) BUT WHEN I DID STEP. 7, I SAW IT WAS (NTSC).JUST FOLLOW THE STEPS.GOOD LUCK.I SOLVED MY PROBLEM IN 6 HOURS :p
Posted on Feb 10, 2009
smokintdi
  • 7 Answers
SOURCE: EasyCAP Video Adapter with no video
Ok, here is what is going on. The default video setting in control panel> scanners and cameras> syntek 1160 is pal-b it should be NTSC_M. Right click on the Syntek 1160 and click Video Decoder Property. Change it to NTSC_M from Pal. Do this with the unit plugged in or it wont be displayed in the Scanners/Cameras options box. Right away the signal line should rear 1 from 0 with video hooked up. Keeping that setting to stay is my issue right now. I was so excited to figure it out, I had to post. I was about ready to throw the unit away. Its a program driver error. Hope this helps!!!
Posted on May 20, 2009
How To Install EasyCap On Windows 7
easycap was not meant to used on windows 7 (i think). but i have uploaded all my easycap drivers for you,.... as always right click exe's and in compatibility mode for windows xp service pack 2. if it still not working after driver install go device manager try update drivers from there.
easycap reccomend - ulead video studio for video editing.
the rar file has no passwords. easycap driver and stuff
Apr 22, 2016 | DekCell EasyCap USB 20 Video Capture...
Tip
Windows7 64bit & EasyCap directions
Ulead Video Studio SE DVD how to run on Windows7 64 bit systems by Not you. Drivers updated now has drivers for XP Vista and Windows 7 7/16/2010 Getting started,you will need another program its called USB-AVCPTSetup_For_Win7 you can get it here... download links are at the bottom of page.Do not install at this point save to your desk top! Ok your ready Do not plug in your Easy cap usb drive. 1. Put the EasyCap disk into your CD Rom When auto play starts click Run HAutorun.exe a window will open DO NOT INSTALL THE DRIVER !!!! 2. click Install Video Studio,complete the install adding your code with no driver reboot when asked. after reboot remove the disk you will not need this anymore. 3.DO NOT INSTALL THE EASYCAP USB DRIVE YET. 4. Install the software you saved to the desk top (USB-AVCPTSetup_For_win7) reboot your system. 5. Plug in the EasyCap USB stick and wate till the driver installs this will be done auto,in a few seconds. 6. Sorry to say but you need to reboot now. leave the USB drive in its port. You are now installed but your cam will only show a black screen at this point,its ok we are now going to resolve that. Start the Ulead Video Studio. During the start up you'll have the choice of VideoStudio Editor or Movie Wizard click the 16:9 ckeck box at the bottom then click VideoStudio Editor. New window will open click Capture,now look for capture video button on the right side of the black screen,click it Just to the right you will see an Options button click. A drop down will show,look to see if input source is in dark letters,if so open and set source to NTSC/M and composite video is checked. If the input source is greyed out,open Capture properties directly under the input source,a new box will open click properties a new box will open this box will have 3-4 tabs you only need the first tab called Image tab under video sources click ntsc/m and composite video click ok click ok again thats it you should now have video,After any restart you will need to reset ulead up again,you should be good to go...... Hope this helps :-} Here are some pic's to help.Note after the instalation,if you move the Easycap usb drive from the usb port it was installed in and input it into any other port it will not work,the driver will need to be reinstalled!!! 09c750d.pnge0aeff9.png78f955a.png New download links For Windows XP/VISTA/7 32-Bit, please download Windows 7 64-bit This web page I have not goten any link to open but thought I'd add it so you all can see it,if anyone gets it open please post any or all links for us all. Thats all for now I'll upload more as I get them. ps working with a company rep now,update for easycap d60 4 input style,If not getting a picture on input 1 move to 3 for setup and one camera setting.
on May 25, 2010 | DekCell EasyCap USB 20 Video Capture...
Cannot innstall easycap
To install Easy Cap go to http://www.worldstart.com/easycap/ download driver, extract to desktop, install Ulead Video-studio, go to Device Manager, find USB Video Capture, right click, click Update driver, browse My Computer for driver software, click Browse button find folder (driver) on desktop click next everything should install. If you have 32bit it will work if 64bit it will not function. You will need to make some changes Ulead Video-studio like source, volume so-forth.
May 20, 2010 | Scosche Industries SCOSCHE FD1436BLKB CAR...
Video Studio 8 freezes on 'Change Field Order' popup
I have just purchased and installed this device and software and was having the exact same problem as you. After a few hours of restarting and reinstalling things, I discovered that I did not have DirectX 9 installed. After I installed it (from the supplied EasyCap CD)the issue was resolved. I hope this fixes your problem too!
Feb 27, 2009 | Ulead Videostudio 8 for PC
Jan 09, 2009 | Ulead Videostudio 8 for PC
EasyCAP USB 2.0, can't install driver from CD, Window Vista
Your going to need to download the drivers for it off the internet. The same problem happened to me so i decided just to search for the drivers. I downloaded them, and then when i was installing it asked "Search computer for drivers" so i did that and found where i had downloaded the drivers to and then the EasyCap Capture Card worked. The only problem is you will need a good recording program to record with because the program they give you probably will not work. I decided to download AmCap which is a software that lets you record with your Easycap. Also i downloaded Pinnacle Studios 12 to record. If you have a Windows xp computer you can use Windows Movie Maker to record.
Dec 10, 2008 | DekCell (CPA-1040)
Ulead Videostudio 8 for PC Logo
326 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
