Question about Sony KDF-E55A20 55 in. LCD Television
SONY KDF-E55A20 MY INDICATOR LIGHT BLINKS SIX TIMES COULD IT BE THE LAMP
  • MALOOTZ Apr 14, 2008
    I WAS WATCHING TV WHEN ALL OF A SUDDEN THE TV SHUT DOWN I TRIED IT AGAIN NO RESULTS THE INDICATOR LIGHT FLASHES RED SIX TIMES COULD IT BE THE PROJECTION LAMP
  • sergiy2004 Jun 16, 2008
  • 84 Answers
No it sounds like the thermal fuse.
Posted on Apr 19, 2008
  • 43 Answers
The thermal fuse is most likely open. I would also suggest replacing the sirocco fan which mounts on the optical block. It's probably clogged with dust. Replace these 2 together and have the unit cleaned out of dust. This should fix the tv.
Posted on Jun 17, 2008
Kdf-e55a20 red blinking light
Altho you do not say which light is flashing red , you have a light on the front that is for the lamp ONLY...
If you do not have the user manual , get it here & start on page 11.:=>...
http://www.retrevo.com/...myTrevo.jsp?page=man
Jul 06, 2015 | Sony KDF-E55A20 55 in. LCD Television
My sony kdf E55a20 does'nt come on ,has two red light's on blinking, the other not
the set may or may not have the self check feature--set off with the Sony remote hit display, 5, vol down and power.
Oct 29, 2012 | Sony KDF-E55A20 55 in. LCD Television
Sony Bravia KDL46XBR-LCD. No picture but sound. Trouble shooting light blinks 5 times in cycles. What does it mean.
If your television blinks 5 times or for a count of times, it simply is indicating that there is a problem inside the unit.
The problem applying to this situation is a faulty lamp. The lamp is bad and simply need to be replaced.
As soon as you replace the lamp, the television will be in good condition once again.
Take care and good luck
Nov 06, 2010 | Sony KDF-E55A20 55 in. LCD Television
The on lcd little light blink six time
The standby light blinks to indicate problems with the TV. Six blinks indicates an internal problem, I suspect with the lamp. I recommend contacting a Sony repair shop to vacuum out the TV and replace the lamp. Installing it yourself has no bulb warranty and you cannot vacuum it out without taking it apart. Lamps are $250+ each...
Mar 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Hello our sony grand wega KDF e55a20 has the green standy light blinking over 50 times then turns 5 red blinking lights. please help. thanks
Symptom shows Lamp is not working and either lamp or its drive board is bad that will be replaced.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual.
Thanks.
Jan 20, 2010 | Sony KDF-E55A20 55 in. LCD Television
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
Bad "GM Board" - power light flashes 6 times
you have a bad lamp.that will cause the same problem
Jun 30, 2009 | Sony KDF-E55A20 55 in. LCD Television
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Dec 04, 2007 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
424 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
