Sound Card info.
I'm pretty sure my sound card is not working, I plugged in headphones to the jack and cannot hear anything when a music file is played with i tunes. It was working until 3 or 4 days ago. Is there a way to check? I really don't even know what type of card I have. I have checked the volume levels, mute options etc. all to no avail. Any feedback would be appreciated. Thanks, David
  • 25 Answers
Check the device manager listing and see if the sound card is listed under Sound, video , game controllers. If it shows a Yellow Exclamation point, it means there is a driver or resource conflict. If a Red indicator show, it means it has been disabled somehow. Also make sure the headphones are tested on another PC with working sound. This will verify the heradphones are still good.
Posted on Apr 30, 2008
Audio static
That's pretty normal with built in connectors. For a workaround grab a cheap USB sound card from eBay or somewhere else. It worked for me.
High Quality External USB 2 0 3D Virtual 7 1 Channel Audio Sound Card...
Apr 08, 2017 | Lenovo IdeaPad Yoga 11S Touch - 59370514 -...
Sound no longer comes out of monitor. I believe nothing is muted. I replaced cable between monitor and desktop. Any suggestions.
You didn't provide a model for your Envision monitor, so I can provide specifics - but here's a few things to try: (1) Start an audio program on the computer (mp3, CD audio, movie, etc. (2) Disconnect the audio patch cable from the computer's speaker jack and plug in stereo headphones. Adjust the volume on the computer's audio control panel to set the volume. If you're not receiving any sound - make sure you're plugged into the speaker jack (this is often the green jack). If you now hear sound, continue to (3). If you are unable to hear any sounds - your problem is INSIDE the computer. More on this later. Continue to the next step. (3) Disconnect the headphones and try the audio patch cable between the computer and monitor again. Make sure you're using a stereo cable - it has 2 individual contact points on the plugs - mono cables have just two. Pay close attention to the jacks if more than one are offered on the monitor (some monitors have power output jacks, etc.). Select the "LINE IN" or "SPEAKER IN" jack on the monitor. Be sure the plugs are firmly seated into the jacks on both the monitor and computer. (4) Check the menu settings of the monitor to make sure that the speakers are enabled (or not disabled as the case may be).
if you were unable to hear audio in step (2) above, there is a problem with the audio circuit in the computer. Some things to check are: Is there a volume knob on the sound card that is turned to minimum? Are (all) the correct drivers installed for the sound card in control panel? Is the sound card enabled? Does the sound card have a problem indicated by an "x" or "!" on the icon in control panel? Many times, "uninstalling" the device in control panel and the "scanning for changes" to reinstall will solve the problem. Other times, it is an output device issue: Have you selected "Speakers" as the output (not HDMI or Digital Audio).
If still unable to get sound working, provide the Envision model number along with computer name & model or the sound card name and model. If the sound is built into the motherboard, provide the mother board name and model. With that info, it will be easier to get the info you need.
Hopefully, you got the sound working with the tips I provided above. Please rate my reply. Thanks.
May 23, 2011 | Envision Computers & Internet
Whycant hear anything
1- raise the volume .
2- check if the headphone is working using local files music .
3- check if sound card recognized , you need to install driver for it .
4- make sure you inserted the green plug to green in sound card holes .
Apr 24, 2011 | YouTube Videos
No sound
Here are some things to check:
  • If you have external speakers, make sure that they're plugged into a working power source and that they're turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, make sure that the cable that plugs into your computer is plugged into both the speakers and the correct jack on your computer (the jack that goes to your sound card). Most sound cards have at least three jacks. Plug the speaker cable into the line-out jack. This jack often has a symbol showing an arrow pointing away from the jack. If the jacks aren't labeled, check the information that came with your computer to see what each jack does.
    ?id=8440e487-7ae3-427b-a9b7-c861a5521758Most sound cards have at least one line-out jack to connect speakers and a line-in jack to connect an audio input device.
  • Make sure the speaker volume isn't turned down too low or muted. This is particularly important for laptops, which often have small speakers that can be hard to hear.
    1. Click to open Volume.
    2. Move the slider up to increase the volume.
      Make sure the Mute button is not turned on. If the button looks like this: ?id=6b62e2ae-431c-4fb5-8905-aaaea5b445a4, muting is turned off. If the button looks like this:?id=0f47efa2-ffcc-466d-a723-bd0ce4640578 , click it to turn off muting.
      Note
      • Some laptops have an external volume control on the outside of the case. If you're using a laptop, check the external volume control to make sure it's not turned all the way down.
  • Make sure your headphones aren't plugged into the line-out (headphone) jack of your sound card or computer (unless you want to listen with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
  • If your computer is supposed to have a sound card, make sure that the sound card is installed and that it's working properly.
    You must be logged on as an administrator to perform these steps.
    To make sure that your computer has a sound card
    1. Click to open Device Manager.‌ ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. Double-click Sound, video and game controllers to expand that category. If a sound card is listed, you have one installed. If no sound card is listed, check the information that came with your computer to see if there's supposed to be a sound card installed. If there should be a sound card installed, you'll need to install one. See Install or remove a sound card.
      Note
      • If you think you have a sound card installed but you don't see it under Sound, video and game controllers, double-click Other devices to check for any audio devices listed there.
    To make sure that your sound card is working properly
      If there's a yellow question mark next to the name of the sound card, there might be a problem.
    2. Double-click Sound, video and game controllers to expand that category, right-click the name of the sound card, and then click Properties.
    3. Click the General tab, and then check the Device status box to identify problems with the sound card.
      If there's a problem, you might need a new driver for your sound card. For more information, see Update a driver for hardware that isn't working properly.
If these actions don't solve the problem, there might be a problem with the hardware for your sound card, although in most cases sound problems are caused by missing or out-of-date drivers, or a problem with your speakers. If you suspect you have a hardware problem, contact the manufacturer of your computer or sound card.
Feb 17, 2011 | HP Compaq dc7100 Small Form Factor PC...
Creative sound card! no sound!
Check whether you plugged in the speaker wire into the correct jack at the back of the computer (it should go into the green colored jack on the sound card).
Did you try playing a sound file? Does media player show the file as playing, but you can't hear anything? Or do you get any error? if there's any error, please mention the error.
If the sound plays but you can't hear anything, again, check the speakers are connected to the correct sound jack. Next, try connecting a pair of headphones or earphones (lower the volume before playing any sound  or music file).
If you still can't hear anything, click Start and type the command "dxdiag" in the Run box and then press the Enter key. In the dxdiag window, click the Sound tab. Check the Notes box, if it gives any error info. If your card is working, it should say 'No problems found." You can also test the sound using the "Test Directsound" button.
If you still can't hear any sound, you should check and reinstall your sound card driver manually after removing it first.
There may be other problems. For more information, check this nice blog post about sound problems.
Hope that helps.
Regards,
Raspal
Jun 14, 2010 | Creative Labs SB0400 Audigy 2 Value Var...
I have no sound in speaker
did you try all the jacks on your sound card? try plugging a headphone in the output jack,or try plugging the headset ia all the jacks to hear If no go make sure the drivers are installed.if still no go replace the sound card.
good luck
Sep 09, 2009 | Intel ESS ES1868F Sound Card
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Soundcard acer aspire 5630
Laptop speakers are usually **** so you could spend a lot of time and money on something that won't make a difference. Try plugging in external speakers to the headphone jack. If the sound is good don't bother looking for a fix.
Apr 27, 2009 | Acer Aspire 5630 Notebook
Compaq CQ50 Laptop
If the sound works on you headphones the either your built-in  speaker(s)  is/are  bad or more likely the headphone jack itself is broken and not making contact in the speaker position which is fairly common.
Feb 28, 2009 | Compaq Audio card Sound Card
 Grubhead
Grubhead
