FixYa.com
Tags:
Vanguard International Blue Flame - Medium Open Flame Patio Heater
Vanguard heater model vp2800btb
posted by slowjam on Apr 14, 2008
my heater will light, but after two or three minutes it goes out including the pilot light.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 07, 2008
Not Rated (0)
soleman13au
Rank:Wiz Wiz
Rating: 88%, 27 votes
Best Solution posted on May 06, 2008
soleman13au
Rank: Master
Rating: 90%, 19 votes
Hi slowjam I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the pilot light may pay you to hit it with some compressed air as well. Hope this helps. Regards Bryan
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Heaters problems?
Heaters
Manual required
I have a Vulcan Electric Wall... Answer This...
Heaters
Solar power cell
I need a solar power cell to... Answer This...
Heaters
Ptac grille
Did you ever find out about the... Answer This...
Heaters
vulcan oil heater
My heater has been working fine... Answer This...
Vanguard International Blue Flame - Medium...
pilot unit goes off upon demand
unit brand new but pilot goes... Answer This...
Repair Service
Find Heater Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
