Question about Whirlpool Duet GHW9150P Front Load Washer
Error code F01 on my whirlpool front loader? any help is appreciated
  • 1 more comment
  • scafarella Jun 08, 2008
    I've tried turning it off and unplugging it. It will NOT wash.
  • Anonymous Sep 13, 2008
    error f01
  • pedror Nov 20, 2008
    Same problem. Service technician says it needs a new "Motor Control Unit". No part available anywhere in Canada, on backorder in U.S.. NO estimate of when this part will be available - this is incredibly bad.
  • 3,230 Answers
Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU. thanks
Posted on Jun 06, 2009
Error code F01 E02
For how long did you unplug the power cord? If it was under 5 minutes, unplug it for longer. Check if that clears the error code. If it doesn't, the motor control unit needs to be replaced.
Please double check your model number to get the correct part. Most of the Whirlpool washers have model numbers that start with 3 letters.
I hope this helps.
Dec 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Error code f01
all I can say to that is if you arrange the bath rugs in a balanced way so they are equally distributed then the problem should go away eric
Dec 29, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open,error code f01
Problem isnt solved, seems like several people are having the same problem with whirpool front load washer with the F01....sad nobody will help you, they want high priced as those machine are............dont buy whirlpool......
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When time to drain pump drains water then just hums and it wont spin, get error code f01. when i turn dial to drain and spin pump just hums drum might turn a little but it never spins. i have emptied...
f01 is main controller (board) failure.
Replacing it is the only solution.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer codes F01/F33, have cleaned the pump and
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start. Error code f01 shows.
Hi F1 means your CCU is bad and needs to be replaced sorry :( If you have any other questions please feel free to comment again. Mike e63dqt.jpg
Nov 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader door locked
My Tech sheet reads F01 is a EEprom Error ? Unplug washer or disconnect power for at lease two minutes. EEPROM ERROR A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. Possible Causes/Procedure ■ A power glitch may cause this error. ? Verify CCU operation by running a Diagnostic Test or any cycle. PUMP DRIVE ERROR The pump driver fails to activate. ■ Replace CCU board. MAIN RELAYS ERROR ERREUR - One of the main relays is not working properly. Possible Causes/Procedure ■ The relay might be soldered or always open. ? Replace CCU board. Good luck and let mre know what you come up with
Sep 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
509 people viewed this question
Dan Webster
Dan Webster
Sal De
