2001 Hyundai Accent Logo
Posted on Jun 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am replacing my front wheel bearings on my Hyundai amica gsi 2001 model manual, i have done bearings before but never a Hyundai , is there a guide on the internet anywhere that i can follow. i cannot find the amica on the drop down list therefore i had to enter the accent
Anonymous
Level 3:
  • Master 4,793 Answers
  • Posted on Jun 19, 2010
Anonymous
Master
Level 3:
Answers
4793
Questions
0
Helped
1544733
Points
14368
Wheel bearings are the same all over,no problems...do the nut up tight then back off 1/8th turn...
Part number & where to source output shaft bearings for 2003 uk reg 1.6 litre manual Hyundai Coupe.
The easy way is to go to the dealership parts department. They would keep those in stock. Or you go to a spares motor factor like the ones below. They are picking up 'wheel bearings', but they can supply all bearing parts..
Wheel bearing for HYUNDAI Coupe II (GK) - Buycarparts.co.uk
https://www.buycarparts.co.uk > ... > COUPE (GK)
Hub bearing for HYUNDAI Coupe II (GK) Petrol / 1.6 - 2.7 liters / 2001 - 2009 MY ... G4GC 02/2003 - 08/2009; 2.7 V6 (121 kW / 165 hp) G6BA 01/2001 - 08/2009 ...
Missing: manual ‎' Must include:
manual
Wheel bearing for Hyundai Coupe gk - AUTODOC
https://www.autodoc.co.uk > ... > HYUNDAI > COUPE
Wheel bearing rear and front for HYUNDAI COUPE (GK) from 2001 MY from various OEM part manufacturers. Huge brand selection at low prices ? Hub bearing for ...
Missing: litre ‎output
Transmission output shaft bearing. - Hyundai - JustAnswer
https://www.justanswer.com > hyundai > 94h1d-transmi...
Jun. 3, 2015 - Transmission output shaft bearing. problem. Our 2005 Hyundai Accent stick shift. Parts errand car. Replaced CV - Answered by a verified ...
1 answer · Top answer: See the answer on the image
Missing: reg ‎' Must include: reg
How do I change the front wheel bearing in a 2001 Sonata 6 cyl
jack the front off the ground remove the tire remove the brake caliper remove the rotor remove the bolt hol;ding the front axle into the spindle hub, remove the hub and bearing.
How do i set up the timing / fit a new timing belt
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
My central locking will not work the key will only lock or open the driver side door. Is this an easy problem to fix and how much will it cost if I bring it to a garage. My can is a 2001 Hyundai Amica GSI...
Best guess and best solution - have it diagnosed by a qualified technician. This way you'll find out exactly what's wrong and what's required to fix it (parts, labor, etc.). You may have to pay the diag fee, but you'll also find out what's causing the problem and maybe decide to fix it yourself.
2answers
Did they make a repair manual for the 2001 Hyundai Tiburon ??
There are several sources from which to get your owner's and service manuals, including going to the manufacturer of the car, and these:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Owners_Manual_Lost_Need_Replacement.htm
1helpful
Cant find info or book on repairing the front wheel bearrings on my car,or even a "manual" for a 2001 Hyundai Tiburon!
Yes autozone.com has a repair guide for your car,you will be able to get the steering knuckle off,this is where the bearing is but ir requires a press or an equivlant to remove and replace the bearing.
Where do i find a repair manual for a 2001 hyundai accent GSI
www.hmaservice.com once you have registered, go to shop tab put in model of car your manual will appear.
4helpful
Front side light replacement
inside behind the headlight there are twist off caps just twist them off and your in/ Please rate my response thank you very much
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
