Question about Jenn-Air JBL800 Work Top Blender
Looking for replacement power cord for Attrezzi blender
I understand that all the Attrezzi collection used the same interchangable power cords, but no online source has had in stock. HELP - I'd take any color at this point, but white would be my first preference.
  • 4 Answers
Have a white power cord make an offer! Contact me at .
Posted on May 01, 2009
Glass Jug replacement for National Blender
I have that exact same blender, and I'm missing the lid. Are you still interested in the jug?
May 14, 2014 | Sanyo 5 Piece Cord Free Collection...
Broken blade housing
I have the whole blender. White with a red glass pitcher. I have only used it twice. For ice. What would you pay for the whole blender? You would then have a back up of it all. Works fine. Just too heavy for me.
Jun 18, 2013 | Jenn-Air JBL800 Work Top Blender
In dire need for a lid and power cord for this blender
Power cord is pretty standard for appliances/desktop PCs/printers. I would try the local Goodwill, they all have a wall with cords for every manner of appliance. On any given day, my local Goodwill has them in black and grey. Or any electronics store will have them.
As far as the lid - I'm not sure if you lost/broke the entire thing or just the plastic cap in the center. That Jenn-Air center plastic piece is easily broken. Your local Ace Hardware or True value sells replacement Blender cap inserts. Glass center with aluminum washer/nut that screws on from below. Looks better than original and won't yellow.
Nov 28, 2012 | Jenn-Air JBL800 Work Top Blender
Owners manual for oster 2 speed blender model 4125
2 3
When using electrical appliances, basic safety precautions should be followed,
including the following:
• Unplug cord from outlet when not in use or before cleaning.
• To protect against risk of electrical shock, do not immerse the cord,
plug or motor base in water other liquids.
• Do not let cord hang over edge of table or counter or touch hot surfaces.
• Never leave appliance unattended when in use.
• Close supervision is necessary when used near children.
• Avoid contact with moving parts. Keep hands and utensils out of jar
while blending to prevent personal injury or damage to the blender.
A rubber spatula may be used only when the blender is not running.
• The blade is sharp. Handle with care.
• Always put the lid on the jar before operating the blender.
• Do not operate any appliance with a damaged cord or plug or after
the appliance malfunctions or is dropped or damaged in any manner.
Return the appliance to the nearest Authorized Sunbeam Appliance Service
center for examination, repair or electrical or mechanical adjustment.
• Do not use outdoors or for commercial purposes; this appliance is for
household use only.
• Use this appliance for its intended use as described in this manual.
• When blending hot liquids, remove center piece of two-piece cover.
• To reduce the risk of injury, never place cutter-assembly blades on base
without jar properly attached.
• Always operate on a flat surface.
• Unplug the blender when it is not in use, before taking off or putting
on parts and before cleaning.
• The use of attachments, not made by manufacturer, including canning
or ordinary jar and processing assembly parts, is not recommended
by Sunbeam Products, Inc. and may cause risk of injury to persons.
The maximum rating marked on the product is based on the attachment
that draws the greatest load. Other attachments may draw less power.
Please follow the instructions below to ensure the safe use of the power cord.
• This appliance is equipped with a polarized plug. This type of plug has one
blade that is wider than the other. This plug will fit in a polarized outlet only
one way. This is a safety feature intended to help reduce the risk of electrical
shock. If you are unable to insert the plug into the outlet, contact a qualified
electrician to replace the obsolete outlet. Do not attempt to defeat the safety
purpose of the polarized plug by modifying the plug in any way.
• You may use an extension cord, if necessary, but be certain to follow
these guidelines:
- The marked electrical rating of the extension cord must be at least
120/127 Volt, 60 Hz, 10A.
- The extension must be arranged so that it will not drape over the
countertop or tabletop, will not be within the reach of children
and will not be tripped over.
• Do not pull, twist, or otherwise abuse the power cord.
Sep 03, 2012 | Oster Blenders
How do open a Waring WSB40 Mixer
Blender not working,Power supply is ok.
Jul 26, 2012 | Waring WSB40 Blender
Cyclone blender - on light blinks and it won't operate
Had this problem couple of times. pushed the power cord in the blender as if there is lose connection inside. It worked.
Jan 03, 2010 | Black & Decker Blenders
Blender stops after about 2 seconds on every setting
correct - replacing the cord is suggested and simple.
Aug 04, 2009 | Breville BBL550XL 5-Speed Blender
Need Clear Cap for Lid on JennAir Attrezzi Blender
you can find them at the part number is 12002171 and it only comes in red now.
Jan 25, 2009 | Jenn-Air JBL800 Work Top Blender
Motor won't turn on
Hi , Try to check with multi tester the power cord ,test the two tips of male outlet switch on tested read the continuity /if not reading ,pulout if push type /if permanent open cover below test the test the cord inside to the male plug if does not response cord is problem,check also fuse test both end of fuse not reading fuse buste then replace thats all goodluck.
Nov 12, 2007 | KitchenAid KSB5 Professional Stainless...
Jenn-Air JBL800 Work Top Blender Logo
260 people viewed this question
Top Jenn-Air Blenders Experts
Are you a Jenn-Air Blender Expert? Answer questions, earn points and help others
