Servo light on onkyo m-504 does not come on - Audio Players & Recorders
  • Anonymous Aug 11, 2008
    I have a same problem... what should I do ?
  • Anonymous Oct 30, 2008
    Same problem and not sure what it would take to fix it?
    Any feedback would be great!
Sorry, no easy answer to this one. The servo light not coming on usually means the protection circuit is sensing an issue with one, or both channels, and not allowing the speaker relay to close. One bad channel can cause no output from both channels. This could be caused by one or more bad capacitors, (common in older amplifiers) or a more severe problem, like blown semiconductors. Only way to find out is to have a competent technician pull the cover, and make some voltage checks at key test points inside the amp. This is not a do it yourself job.
Posted on Dec 31, 2008
ARCHOS 504
Did you try flashing the firmware on the unit?
Mar 27, 2008 | Archos 504 500870 Digital Media Player
Onkyo m 504 left side not working
Amplifier section to left side, as well as connection to wire going to left side speakers,and speakers itself shoud check for damage/
Apr 29, 2012 | Onkyo Audio Players & Recorders
I have code 504 check engine light on any idea what 504 is?
It is a brake switch code, hyundai has posted a massive recall on them, though your car may not apply. It will need a switch, I think only 2 out of 500 have been a wiring issue.
Aug 10, 2009 | 2007 Hyundai Sonata Limited Sedan
Onkyo DV-SP405 DVD player says no disc
This woud be due to two things
1. laser
2. servo motor not spinning to the correct speeds i,e Bad motor
Thanks
Jun 11, 2009 | Onkyo DV-SP404 DVD Player
My Archos 504 will not power up.
Press the Reset button on the inside of the unit with the battery removed. This should solve the Problem. If not you may need to send it in.
Reset button is located under the battery. So remove the battery and loo for the button at the end of the archos where the battery pins make contact. To the right of those and half way down between the pins and the case of the hard drive will be a gold round looking circuit. this is the reset. Press it and off you go.
Thanks,
Ed
Dec 23, 2008 | Archos 504 500870 Digital Media Player
Onkyo six CD changer stuck closed, reads "Mechanical Error" in window...Also, new Onkyo tape deck TA-RW255 tape stuck, won't open and won't turn off.
The Onkyo CD changer has an internal mechanical problem that could be anything from a disc being jammed in the mech, to a bad belt, or a bad IC or supply voltage that goes to the servo circuit. No way to be certain without troubleshooting it. You can open it up and see if a disc is stuck, but unless you have some experience in this sort of thing it is better left to a professional, You can cause more damage than you started with by trying to fix something you don't know that much about.
The tape deck could have any number of problems as well. A bad belt or gear, a defective servo circuit, and the list could go on, but they are all things that also should be checked by a professional.
Most of the time a tape won't eject is form the tape head being engaged and not letting loose of the tape. But since it won't turn off, you have some more serious problems. That is an indication of something not communicating with the microprocessor. It could be a digital transistor, a shorted capacitor, and like before, many other things. Whatever you do, don't force the tape deck open. It will destroy the head assembly and it may even void your warranty (you did say it was new).
You need to find an authorized Onkyo service center near you. Contact Onkyo if you can not find one yourself.
This really is the best action you could take. Onkyo is a very good brand, and in most cases is worth getting repaired. If it were some type of cheap-o brand it wouldn't matter what you did to it because replacing it would always be cheaper than paying for a repair. That is not the case with your equipment.
If I can be of further help, just ask me.
Dave
Jun 28, 2008 | Onkyo Audio Players & Recorders
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
Mar 18, 2008 | Archos 504 500870 Digital Media Player
Archos 504 charging
just for mat it . its the best way to recover it
Sep 17, 2007 | Archos 504 500870 Digital Media Player
Onkyo DR-C500 won't recognize discs
Onkyo units as well as several other manufacturers have a common problem where the spindle motor gets intermittant or wont come up to speed.Its not hard to replace this motor, but could be a trick to adjust the platter height. Also the unit probably needs a servo alighnment as well. This unit could also have a simple problem as a dirty laser lens. You can try to use a disc lens cleaner to see if that helps. Good Luck
Jun 24, 2006 | Onkyo DR-C500 Multi-disc DVD Player
393 people viewed this question
 Grubhead
Grubhead
