Question about Electronics - Others
Travel drive broken
I dropped my laptop and my memorex travel drive bent. When i carefully pulled it from the usb port the memory card came out of the plastic casing and the stem broke cleanly from the card. Can it be repaired?
2 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: I dropped my laptop and my memorex travel drive
If you are good wih a fine tipped soldering oron or know a person who is then there is a slim chance you can repair it.
But be prepared for the worst.
Posted on Oct 12, 2009
Bent flash drive
Unfortunately this drive is impossible to repair if bent (like from dropping while attached to laptop) and it cannot be recognized when plugged into your laptop. The silicon memory chip is sandwiched between the PCB material, if you take the case off of the outside you can observe that it is just a black square piece of silicon with no traces on the board only the metal pads to connect it intothe USB port. the "faceted" portion of the drive is only for grip and has no use other than a way to remove it from your laptop. The memory is very close into the connector, so when I dropped my laptop it bent it directly down the middle of the memory chip portion itself, undoubtedly severing thousands of microscopic connections in the chip. I believe this is a very poor design and will be buying the older "switch" style usb drives in the future.
Jan 31, 2014 | SanDisk Cruzer Facet 8GB USB 2.0 Flash...
Laptop will not recognise the drive
Fix by an expert required such as www.SaveMyUSB.com
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Good luck
Jan 01, 2011 | Memorex 6GB Mega Travel Drive HDD Hard...
I dropped my laptop and my memorex travel drive bent. When i carefully pulled it from the usb port the memory card came out of the plastic casing a little and the stem broke. I tried to bend the card back...
Oct 12, 2009 | Memorex Electronics - Others
Travel Drive Broke
It depends on your skill level as to if it can be fixed or not. The data is most likely still safely stored on the flash chip inside the drive casing. However, the USB connector has been just ripped off. If you have any experience soldering it would be as simple as getting a replacement usb plug from an electronics store or cutting a cable you have and then soldering the USB connector back to the flash drive inside the casing. This is something than can be done at home or possible by a repair shop that does any type of soldering work(tv, radios, ect) Most computer repair shops will look at you silly if you ask them to solder a thumb drive back to life. I would not expect more than to be able to mount your drive and copy the data. Odds are after you cut it out of the casing it will never go back in correctly.
Good Luck
Aug 21, 2009 | Memorex Electronics - Others
Pen drive not been detected by laptop.
try connecting it to a diff. usb port.
most likely problemis that the drife may have malfunctioned.
Mar 15, 2009 | Kingston 4GB Secure Digital High Capacity...
TRAVEL DRIVE
generally NO sorry...
Jan 11, 2008 | Electronics - Others
Laptop fell onto floor...now my memorex travel drive is broken...all college papers lost...help
This is actually fairly common, if the laptop still works with the broken USB socket you can take the cheap approach which is just don't use that port. If you need more ports a USB hub is pretty inexpensive.
Nov 27, 2007 | Electronics - Others
Electronics - Others Logo
182 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
