Rinnai freestanding Timberflame error code 11
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Therinnaiguy
  • 1420 Answers
SOURCE: error code 11 on my rinnai
A code 11 also means that it might not be getting any gas. On thr right side of the unit you will find a small door. open it up and make sure the valve is in the open position. If it is, you should contact your gas company to come and diagnose what is going on. The Rinnai is not a do it yourself fix it type of heater.
Posted on Nov 07, 2007
  • 53 Answers
SOURCE: code 11 on Rinnai Avenger 25 gas heater
11 means no gas / failed to ignite - check the bayonet is fully plugged in properly, they can be hard to plug/unlpug - otherwise you wilol have to take it in for service.
Posted on Aug 28, 2009
  • 120 Answers
SOURCE: Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Posted on Jul 21, 2010
aviral_srms
  • 1216 Answers
SOURCE: Rinnai RHFE-263FA showa error code 11..Replace
Error code 11 denotes ignition failure
Ignition Failure
Here is how you can resolve the issue.
1. Check gas supply, gas type, gas pressure. Verify gas supply and make sure gas lines are purged.
2. Check dip switch settings. Is the unit a converted unit?
3. Check condition of flame rod. If dirty determine why.
4. Check for flame current. (see flame current instruction in this guide) Ensure that all connections are tight.
5. Check all gas solenoids for proper voltage and ohms.
if you want a troubleshoot manual get it here
Posted on Nov 18, 2010
  • 11800 Answers
SOURCE: Rinnai Timberflame won't start until
This is the install and operation manual of your Rinnai Timberflame - at the rear you have the electronics schematic.
http://www.rinnai.co.nz/upload/files/productfile/ib35etr_install_and_operation.pdf
As you can see the thermostat in this unit is just a thermistor (temperature variable resistor) and all its functions are predetermined - this is how the unit works. The temperature setting is normally determined inside the unit, using either the buttons on the case or the remote: the room thermistor measures the temperature in the air and it transmits it to the control panel which turns it on when it drops below set temp minus 3 C. If the difference is greater then the room thermistor is badly located - too close to the unit itself and the radiant heat that is stored in its elements skews the air temp reading. You will have to change the location of the thermistor: locate it following the wires from the board then extend them and relocater the thermistor somewhere else, away from the unit.
So if you are using a separate one then it is not an original part of the device, it was added later to automatize it. Because of that i have no idea how it looks and why the differences of temperature are that great - normal thermostats should engage no later than 3 degrees Celsius. To find it you will have to follow the wiring from the oven, it will lead you to thermostat and there replace it with another model.
Posted on May 30, 2011
Error code h
Error code 11 is ignition failure
Error code H is over heat
May 28, 2016 | Rinnai Heating & Cooling
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
Getting an error code of 11
Error Code 11 indicates an ignition failure. Check that the gas supply is turned ON. Switch the heater to STANDBY and the ON again. If the burner doesn't light or you continue to have a problem contact your Rinnai dealer.
Hope this helps you and thanks for choosing FixYa. Cheers ...
Sep 20, 2011 | Rinnai Vent Free Gas Heater/
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heater goes out after 20min error code 12 appears
Definately a gas supply problem. If it was an overheat you would get a different code. Error code 12 meant a flame was there but then went out. The code 11 meant tried to light but no flame sensed. Error code 12 on heaters and Infinites is nearly always a fault on the gas regulator at the bottles. Sure I recognise your company name from up in Queensland. As you might know we hae had problems with an oily residue in some regulators for ages. I am recommending going away from two stage regs and spliting them up with a seperate first stage and then a second stage. Bit more expensive by zero call backs.
May 24, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Mar 22, 2009 | Rinnai Digital Remote Water Heater Control...
No hot water
An error code of 11 equals no ignition. Check gas supply, sparker, flame rod, burner and ground.
Nov 27, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Error code 11 on my rinnai
Nov 06, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
