FixYa.com
Tags:
Whirlpool GU2400XTP Built-in Dishwasher
Groaning washing machine (by 3 users)
posted by twigshed on Apr 14, 2008
I have a Whirlpool Quiet Partner III that is not so quiet any more. It kind of groans at me - a sound that starts out low and grows for a second, then stops and starts again, a pretty regular pattern. It stops sometimes - it doesn't do it constantly throghout the wash, but for most of the time it does. Any ideas what it could be?
Comment by twigshed, posted on May 26, 2008
I finally hired someone to come look at it. The top water arm was clogged with gunk and very little water was getting out. He declogged it, and it sounds much better.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Apr 22, 2008
Loud grinding noise. I believe it could be the motor.
Comment by the breezecn, posted on Apr 17, 2008
continuous screechy noise through entire wash/rinse cycles
Best Solution
Thanks for Trying (70)
IFIXALL
Rank:Wiz Wiz
Rating: 84%, 287 votes
You may have something in the food shredder thats causing the noise.If you remove the bottom panel and look  at the right side about half way in you'll find the pump.You can remove it by hand because it twists off for quick access.MAKE SURE POWER IS OFF FIRST.
Rating Locked! (?) twigshed has rated this solution as Thanks for Trying
Can you Help with these Dishwashers problems?
Water Stayed in dishwasher
Could you please advise why... Answer This...
Dishwasher problem
Hi My dishwasher will fill with... Answer This...
my dishwashers not working
hi. when i put it on for a... Answer This...
WHIRLPOOL QUITE PARTNER ii
it just quit. no lights... Answer This...
clean light is blinking
clean light is blinking. Manual... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
