Question about Bosch 24 in. SHU53 Built-in Dishwasher
Endless cycle with wet dishes
My dw runs forever. Many times it goes up on the time the cycle has left instead of down. Then it gets stuck on 1 minute until I get fed up and turn it off. When I turn it back on, it resets at 13 minutes. On top of all this, the dishes are not ever dry. Any suggestions? Thanks.
  • 3 more comments
  • Franjd Apr 19, 2008
    I have same problem with my dishwasher. It runs all day and the timer does not seem to go down at all. If I open the door then shut it, the timer has added minutes! After its finally done dishes are still wet.
  • 1 minute Apr 24, 2008
    I have the same problem, I think this is a code being displayed, but I don't know what the fix is.
  • orange_cat May 08, 2008
    We are having the exact same problem, right down to the timer resetting to 13 minutes. We've just been watching it and when it gets down to 1 minute, press the two buttons abor Cancel/Drain to end the cycle. Then open the door to let the dishes dry. Sears will be coming out on Monday to repair, I'll post back what we find out!
  • PJDiskin May 19, 2008
    My bosch dishwasher takes almost 3 hours from start to finish. It seems to get stuck at the 1 minute mark which lasts for about 45 minutes. I have ran the hot water in the sink before starting the dishwaster to ensure that the water is hot enough. I checked the filter in the bottom to make sure it's clean. I don't know what else to do. Help.
  • Anonymous May 27, 2008
    Hi yes i have the same problem..
    Thanks Don
    dmar@isp.com
We had our dishwasher repaired. There was a connection on the circuit board that was burned out. The repair guy said that he could solder it, but since we paid for a service contract, he put in a whole new board.
Posted on Jun 09, 2008
Problem conditions experienced point towards the timer.
If it's a Bosch, check for Rinse Agent (e.g. JetDry). Rinse agent is not optional with a Bosch.
Posted on May 12, 2008
The drying time goes for normal mode start at 34 minutes to 30 minutes left then drops to 20 minutes then goes down to 17 minutes left then suddenly it stops and says complete. so the normal mode doesn't...
Yes, I believe the "normal" setting is part of the sensor dry. So, if the sensors, bars located on the inside of basket, do not detect moisture, the time will decrease and eventually stop. Locate the sensor bars, get some scotchbrite pad, and lightly clean the two metallic "bars" on the inside of drum. I find alot of buildup from dryer sheets inhibiting the conductivity of the sensors. I would start from there. If that doesn't fix it then you may need to call for service. hope this helps.
Sep 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Kenmore dishwasher will not fill with water model no 630.1609406. It will run a full cycle but not fill. Water was temp shut off to replace kitchen sink and now dishwasher won't fill with water. No fill...
First, are you sure that the machine is not filling?
I go on calls all the time for this problem and it turns out than the machine fills but the wash motor does not run.This leaves soap in the bottom of the DW so it looks like it did not fill with water. This is a common problem in dishwashers that have not been run for a few months, and is quite common after a remodel. If it IS getting water, the motor is probably stuck. If it is Not getting water the first step is to locate the "over fill" float inside the dishwasher. This will be a round sort of mushroom looking thing on the floor of the machine near the door on the right or left. Make sure it moves freely up and down. It will only move about 1/4 inch but If it is stuck up, the machine will not fill. If float is O.K. then check the water source. Turn of water to DW. Remove the kickplate under DW door and disconnect the waterline from fill valve (should be on front left side of unit). Run waterline into bucket then turn on the water. If you don't get water call your plumber. If you get water then you need to check the fill valve. Connect a volt meter to the 2 wires on the fill valve. Start DW. First the diswasher should start draining, then it will start filling. At this point (a few minutes into the cycle) you should see 120v AC at the fill valve. If you do see 120v Ac, replace the valve. If you don't , then turn off the machine and check the float switch. This is located under the DW right under the mushroom thingy. The switch should have continuity when the DW is empty. If there is no continuity then replace the switch.
Mar 29, 2010 | Dishwashers
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Wet dishes
Hello
The heat dry button must be lit up or you are using air dry instead!
ican
Please leave a rating before you leave
Dec 10, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Frigidaire FDB635RBB heat wash/heat rinse
Most DW today take a minimum of 90 minutes. Run the hot water from the sink until it gets hot, then start the DW, this will shorted the first wash cycle. It is not uncommon for the DW to run 2hrs or more based upon the water temperature entering the DW and the soil level of the items in the DW.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Kenmore Elite
Hmm, I'll start at the top :->. Well, first thing is that Kenmore doesn't manufacture any appliances. The only thing Sears has is the name recognition, therefore, they have GE, LG, Whirlpool, and others to make appliances for them and Kenmore slaps on their label. On with the problems though :-> 1. Door is grungy looking. Make sure your air-gap ( if you have one) is clear and not clogged. If you don't have one, make sure the drain hose is mounted to the underside of the counter, under the sink. This will prevent Gookus from backfilling into your dw. 2. There are 3 main things to check when repairing dw - Circulation, Heat, and Drainage. There's not much else. Here are some tips to address each one. a) Make sure all spray arms are turning. Put in one position, close door, run, open, and verifiy they moved. If not, clean holes in spray arms, or, remove filter and clean around impeller or chopper. I find clogs all the time. b) Heat. Make sure you are running your hot water in the sink until max hot water is reached. This is very important and should be listed in the users manual. Most dw's run several cycles before the heater element is energized. Water must be 120F when entering dw. c) Hard Water buildup. Use Lemon Shine, available from Walmart. This will clean the dw and prevent buildup on dishes. d) drainage. Addressed above. I've seen countless times where food and other gookus goes right down garbage disposal and into the dw drain line, where it recirculates on to dishes. Make sure air-gap is clear or that hose is secured to underside of countertop. e) Make sure the element is working. Once easy way to check is to verify dishes are dry at the end of the cycle. If not, call a service tech and get fixed. I've found black mold (splatter) on inside of dishwasher due to heater element bad. Hope this help!
Apr 05, 2008 | Kenmore 24 in. 15173 Stainless Steel...
Keep running at one minute?
well lots of times there is a mylar ribbion on the control panel that you can un hook and gently clean it with a pencial eraser as they are sensitive to resistance and lots of times this will fix it try it before the control panel im in the usa and havnt had a lot of hands on with bosch
Mar 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
808 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
