Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Broken handle release
The foot-operated handle release on my Bissell 7920 has broken.  I am wondering whether it will cost-effective to have this repaired; it looks like it will be a major disassembly to get to this part, plus the nearest Bissell repair facility is 20 miles away, so that means two round-trips plus probably waiting for the repair shop to order parts.  So I am wondering if I should just buy a new one instead of investing in the repair of a five-year old machine.  Does anyone have experience with having the handle-release assembly repaired?
    President:
  • 1,673 Answers
Most times they don't break, it is the 2 screw holes at the back that back and the top will raise up from the base. If this is the case, remove the 2 screws and install longer ones with a flat washer on them to fashen down the top. But first the top will have to be removed to put the handle release in the right spot. You would probably look at around $60 to repair, unless the top needs replaecment, then it would be more parts.
Posted on Apr 15, 2008
  • Marlene Aug 28, 2011
    When the handle release is broken, it's broken. It has nothing to do with the screws. I know, because mine is also broken, but we can't get the thing out. How do we get it out. It's only a $9.00 part.
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
There does not seem to be a handle release button on my bissell shampooer and I can't get the handle to release. Model 08239 C 082390
Seems like the on/off switch is at the bottom of the handle on one side, and the handle release is on the other side. Both are foot switches; that is to say that they're operated with your foot.
--W/D--
Jan 20, 2011 | Bissell Vacuums
Foot operated release "spring" is broken. Replaceable?
Remove the pieces of the old spring and take it to any OSH store, they have an assortment that will likely have one that will work.
Oct 20, 2017 | Bissell 3590 CleanView Bagless Upright...
The foot release latch has broken or become unlatched on my uprig
I had this problem once before. The only thing I did was loosen the back 2 screws, take the release latch and just play with it until it catches, rea simple.
Mar 19, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 7920 doesnt spray liquid
Ive oredered the pump belt and brush. after receiving and fixing them i will test the spray if it works.
Aug 18, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Foot Pedal Broken
For the handle release, part number is Detent Lever 2030052 Try bissell.com, or call a local repair shop, if they repair Bissell's, then they may have this part in stock. You shouldn't have to take it aprt, there 2 tabs on the release that fit into slots on the base, there move the slots so as to release the tabs.
Jun 21, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Water Leakage
Check the water bottle. Ours has been doing the same but putting a bit of j cloth between what they call the o ring and the cap fixed it. Really you need a new bottle assembly
Jun 13, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
High pitched screeching/broken handle release
For the handle problem, detent lever part #2030052 and costs $4 to $5. A bearing in the motor is what is making it sound bad, part #2032211 and will cost around $60. You could try bissell.com or call them. They can at least let you know who has Bissell parts near you.
Mar 25, 2008 | Bissell CleanView 3596 Bagless Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
140 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
