Question about Brother DCP 130C All-In-One InkJet Printer
Scanner problem I just cant seem to get the scanner to work, printing is good but when I go to use the scanner it says "connecting to pc" but dosent do anything...please help!...thanks Kay
    Novelist:
    Champion:
  • 214 Answers
Have you installed the Installation programs off the disk that came with the unit? Just plugging the unit into the computer may generate GENERIC drivers for the printer but nothing else.
Put the disk that came with the unit into the Disk Ddrive and run the Installation Program. This will install both the Drivers and the Interface Programs for your unit.
If you have installed the Drivers from the disk and it still won't work, try this:
RIGHT click on My Computer - select Properties - then select Device Manager. Any problems will be displayed by having a Yellow exclamation mark alongside the item. RIGHT click the item with the exclamation mark and select Update Driver (have your disks ready). This will install the correct drivers for your unit.
If all of this fails, contact the retailer and get them to check it out (I assume it is still on warranty).
Good luck.
Posted on Apr 14, 2008
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
My Epson NX300 prints just fine from anything on the computer screen but, when I try to print a copy from a copy in the printer/scanner tray the paper from the supply rack drops about 4 inches like its...
Connect the scanner to an old USB HUB, and it will work. It stops when you connect to a new USB connection direct in a new PC. Done it. I worked with a 2 port USB HUB. Was posted someplase but I cant remember where. Magnar Vereide Datainstituttet.no
Oct 31, 2013 | Epson Stylus NX300 All-In-One InkJet...
My laptop omlet to conect a phone charger dosent work enymore
Good Day!
maybe you just accidentally disable the usb port, so that you cant able to char your phone.
Mar 04, 2013 | IBM ThinkPad T40 2373 Notebook
How can I print full bleed on konica Minolta C451
Hi, unfortunatley you cannot print full bleed on any printer that uses toner. The way to do it is to print them on A4 Wide or A3 Wide paper and them trim them like you mentioned.
Sep 13, 2012 | Konica Minolta Bizhub C451...
My epson stylus 680 printerwiil no work if i dont install all of the coloured ink but i just want to print black only
Hy, you can not print if you don`t have all the cartridges in the printer (this is a protection from the producer so your printhead dosent burn out. The only hay is to go to the printer menu in your P.C or MAC and in printing preferences select to print in grayscale. After that your printer will ony use BK ink.
May 25, 2012 | Epson Stylus Multifunction Inkjet Printer/...
I want to print in black and white but cant seem to work out how
Hi Good day.. You can set your printing quality.
To print in black and white, follow these directions:
1. Open the "File" menu on your browser toolbar.
2. Select "Print."
3. When the Print box opens, click the "Properties" button, near the top.
4. Click on the "Main" tab.
5. Check the Grayscale box in the print option."
6. Click "OK."
7. Click "OK" again to print the black and white document.
Hope to help you with my solution.
Regards:
JR
Oct 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Cannot scan to my PC
If you are using a usb connection and can print and have button manager installed then go to control panel to scanners and try to have windows find a scanner. Your driver disk must be in the computer. you have to install the sharp scanner drivers from the disk for it to work. Button manager will let you decide how to use the scanner.
Nov 19, 2009 | Sharp AR-M205 Copier
Cant use da internet
i had the same problem...do you have AVG on your computer. if so turn off all the link scanner options.
Jun 25, 2009 | Computers & Internet
Epson RX425 multifunction
Just cracked it, had same prob...printer would print but wouldn't scan
lost original CD...tryed epson downloads but not the older versions...
i needed the 2.6 version
TRY THIS
http://driverscollection.com/?file_id=24466
Sep 13, 2007 | Epson Stylus RX425 Multifunction...
Dell 810 not printing
Dear chibihamster, It seems that there is some loose connection in your printer. If you have a little knowledge in hardware, please open your printer carefully, check all the connected cable specially the printer head connector. The best way is that disconnect the printer head cable and reconnect it again. Do not do anything in your scanner circuit area, otherwise it will create you more problems. If this doesn't solve your problem, please contact the manufacturer. GOOD LUCK!!
Aug 31, 2007 | Dell 810 All-In-One InkJet Printer
Brother DCP 130C All-In-One InkJet Printer Logo
99 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
