FixYa.com
Tags:
Intel Pentium 4 Socket 478-Pin Cooling Fan  CPU Cooling Kit, Cooling Fan
Intel Pentium 4 CPU: 423 Pin versus 478 Pin
By pawa - usenet poster
Dear friends,
Does anyone know any major problem with the Intel Pentium 4 CPU, 423 pin
compared to 478 pin?
Kindly enlighten me asap as I may be buying a 2nd hand PC with a Pentium 4
CPU(423 pin) running on Intel motherboard(D850GB).
Thanks alot,
Merrvyn
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hello
NO
Alvin
snape @hotmail.com
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
Merrvyn,
The first-generation Pentium 4 chips had 256KB of full speed cache, were
made on the 0.18micron manufacturing process, and came in the socket 423
formfactor.  This is referred to (codename) as the "Willamette" core.
Later on, the same core was put into the socket 478 package, which of course
required a different socket and motherboard.
Current Pentium 4 processors still use the socket 478 package, but are now
the so-called "Northwood" core - 512KB of full-speed cache, and the 0.13
micron process (meaning that at any given speed, they run cooler than an
equivalent speed 0.18micron part).
There is better information on this at:
http://www.intel.com/support/p rocessors/pentium4/p4compare.h tm
The D850GB motherboard is a great, very reliable board. Full specs are at
http://support.intel.com/suppo rt/motherboards/desktop/d850gb /. I had one
myself once.  The only "major problem" I can think of is that the socket 423
parts topped out at 2GHz - in other words, you won't be able to upgrade the
PC beyond 2GHz without swapping the motherboard.
Feel free to mail me if you have more questions.
Hope this helps..
Solution #3
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
There are two variants of Northwoods:
The A variant, which has a 400 MHz front-side bus
and the B variant, which requires a 533 MHz front-side bus.
Both have 512K of full-speed cache onboard.
Any motherboard that supports B-series Northwoods will also support
A-series, but in most cases the reverse is *not* true (the only known
motherboard that supports B-series Northwood P4 CPUs and *SDRAM* is
Gigabyte's 8ID533); motherboards that support B-series Northwoods and have
Intel chipsets usual have the later variants of the 845 chipset (G, GV/GE,
PE, PV) 850E, and E7205 chipsets, which require either RDRAM (850E) or DDR
(845 series *except* the original 845, and the E7205).
Christopher L. Estep
Solution #4
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
www.intel.com   The 478 is a newer chip, with improvements.
The 423 will run, but don't pay too much, it is not current
technology.  I think the 850 chipset mobo requires RDRAM
which is more expensive to add more, be sure you consider
the cost of meeting minimum XP requirements before you buy.
You can buy a basic new Dell for less than $700.
Be sure you get all documentation and media with any used
computer, including key numbers.
I don't think it is worth more than $200-300 dollars for the
computer, keyboard and mouse. The software bundled isn't
worth much if you don't need it.
| Dear friends,
4 CPU, 423 pin
with a Pentium 4
| Thanks alot,
| Merrvyn
Solution #5
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
aye 55 pin shy!
:: Dear friends,
:: Does anyone know any major problem with the Intel Pentium 4 CPU, 423 pin
:: compared to 478 pin?
:: Kindly enlighten me asap as I may be buying a 2nd hand PC with a Pentium
:: CPU(423 pin) running on Intel motherboard(D850GB).
:: Thanks alot,
:: Merrvyn
Can you Help with these System Cooling problems?
System Cooling
damaged printed circuit board...
I don't think I'm in the right... Answer This...
System Cooling
Air Condition
Ac only works for a minute or... Answer This...
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
