Xerox 416si print or copy are dirty
When copy or printing the paper has raised letter at the center and the copy has black dirt at the center, I have been told it is the fuser, Is this correct. However complete fuser are expensive, can I change one part of the fuser.
Thank You
  • yo5861 Apr 15, 2008
    How do I takeout the fuser is there any step by step instruction website or documentation.
    Thanks
  • 239 Answers
Yes, this is very difficult even for a Xerox Service Rep to service the entire fuser assembly.
If you can buy the entire fuser assembly do that instead. You will get new fuser sensors and components with it. this might be very expensive, but if you know what you are doing, the fuser can be replaced.
We are not talking about other problems you might have with the copier, just the fuser assembly.
If Xerox has a call charge that includes the cost of the part(s) and labor, by all means, "TAKE THE CALL CHARGE!!!!"
It is much cheaper to pay that then the detailed service list not including the per 15 minutes of labor.
Posted on Oct 17, 2009
  • 29 Answers
The problem is upper heat roller of the fusing unit are defective.try to ask xerox u.s.a if you can buy only the upper heat roller.
Posted on Apr 14, 2008
  • wilfredo benito Apr 16, 2008
    only a technician can help you to pullout the fusing unit.because ther is a very sensitive parts located in fusing unit.ok
Print is fully black
often when the exposure lamp burns out, all your copies will come out black. The light reflects off the immage to the drum to create the copy to be printed to the paper. If the light is out, all the drum will see is a black image to be printed. Make a copy with the cover open, and see if the light turns on.
Nov 04, 2014 | Canon IR2016J
Printer producing dirty copies
it could be that the roller needs cleaning, how you do that, I don't know, but that's my guess. try printing blank white pages and see if they come out dirty
Nov 26, 2013 | Xerox WorkCentre Pro 555 Plain Paper Laser...
My Xerox 4150 keeps taking lots of blank pages through when printing multiple page documents sometimes 30 or 40 at a time
Two possible solutions to your problem.
If you are talking about grabbing more sheets than one from the tray, you need to make sure the tray guides are up flush against the paper.
If on the other hand you are talking about scanned/copied jobs, check the setting for your scanner, it may be set to letter size which is longer than A4, so the machine thinks it needs another sheet to complete the job causing a blank page to be sent.
Hope this helps
Jan 10, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Kyocera cs 2050 copy has faded print down center
make sure the glass is clean it sounds like you either have a dirty scan glass or the wires need to be cleaned there should be a cleaner on the front cover of the macin that you you pull out and slide back abd fourth to clean it
May 05, 2009 | Kyocera CS-2050 Black and White Copier
Xerox docucolor 12 copy/print printing all black
If you moved the printer, make sure the conections from the printer to the Fiery are secure. If loose the prints will be black but when copying will be fine.
Jul 19, 2008 | Xerox DocuColor 12 Printer
GRINDING NOISE or PAPER JAM
If you are not a technical person best thing to do is to show it to an expert. grinding noise means some part in the machine is running with the friction. and might brake something or scratch something. Find out persons who work on photocopiers in your area either samsung or Xerox. as this model comes with both the companies and Xerox people are generly better than samsung people.
Apr 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
k24674
jasbo
jasbo
